Hypertech Advice
Old Mar 13, 2005 | 08:43 PM
zr2tim's Avatar
zr2tim
Default Hypertech Advice
OK..pretend I'm stupid (won't be tough)...
I have an un-modded 93 LT1 Automatic.
Stock intake and Exhaust.
If I bought a Chip & 160 thermostat, what all will
it do for me?
Please expound......
Old Mar 13, 2005 | 08:50 PM
tjwong's Avatar
tjwong
it do for me?
If you got the "Thermomaster" chip your fans will turn on earlier to take advantage of the 160 degree stat and it will give you a very generic performance tune. You may see a couple Hp as all they do is bump the timing a couple degrees across the board.
Old Mar 13, 2005 | 08:59 PM
TA's Avatar
TA
what all will
it do for me?
Um.........lighten your wallet
Old Mar 13, 2005 | 09:05 PM
zr2tim's Avatar
zr2tim
So basically, you guys say it isn't worth it?
Is it because if the type of chip I described, or
any chip in general?
Old Mar 13, 2005 | 09:47 PM
tjwong's Avatar
tjwong
Most aftermarket chips fall into that category especially Hypertech, and JET. Unless you get a full blown custom burned chip to your specs it is a very generic tune. But in reality unless you have some mods such as a cam, ported heads and things like that, a chip really won't do much for you. Unless you just want to lower your fan turn on temps.
Old Mar 14, 2005 | 12:53 AM
vader86's Avatar
vader86
Generic chips are pretty worthless.
It'll do well by changing fan settings, but the 'performance' settings are useless and since you dont have the electronic transmission, its not going to help that either.
Old Mar 14, 2005 | 01:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
I got smacked by the Thermomaster bug when I got my first MAM catalog. Guess I should put it in if anything for the fans.
Old Mar 14, 2005 | 05:32 PM
TA's Avatar
TA
True that if you get the right Hypertech chip, it will bring the fans on a lower temp, but you can achieve this with a simple replacement temp switch which costs around $20
Old Mar 14, 2005 | 05:37 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
If you want a chip I'll sell you one I've got sitting around I think it's made by ADS, email me if you're interested.
on sale this week only!
Old Mar 14, 2005 | 10:09 PM
86C4EVER's Avatar
86C4EVER
When I bought my 86, it had a Hypertech chip. Last year, my computer was giving me problem, so I reenstalled the stock chip. That did not solve my problem, so I replaced the computer, with the stock chip. Big difference, at full throtle. I really think it does improve perf.
No proof, (dyno), but I can easely break loose in 2nd gear with the chip, but I have to hamer it with the stock chip, and it will not break loose like it does with the Hypertech.
Old Mar 15, 2005 | 07:52 AM
runner140*'s Avatar
runner140*
Default Hypertech
Many members call hypertech, hypercrap. That being said, hypertech with a 160 tstat will communicate with the computer to turn the fans on earlier BUT your vette will not necessarily run cooler. If you want your vette to run cooler, first class maintenance (flush system etc.). Hypertech will change shift points but that will not make you run faster. Just my .02.
To Hypertech Advice
