valve Seals
May 30, 2005 | 12:52 PM
valve Seals
Which do you prefer, GM or Felpro? Also, if you prefer GM. Do you have a part # for an LT1.
May 30, 2005 | 12:56 PM
St. Jude Donor '14
stay away from the white teflon crap seals.
May 30, 2005 | 02:24 PM
Cruise-In II Veteran
Since my OEM seals lasted over 100k miles I went with them; and you know they will fit with no problems.
May 30, 2005 | 02:34 PM
Quote:
Either one would work OK. Another brand is PC or Perfect Circle but I think they were swallowed up by Federal Mogul. FelPro I beleive is the vendor to GM.
May 30, 2005 | 02:38 PM
10212810 Black ones for intake.
12564852 Red ones for exhaust...from GM a couple of years ago.
CNC also included the black ones for both intakes and exhaust...about 28 bucks from Superior Chevrolet for 16.
I have no complaints.
May 30, 2005 | 03:16 PM
Felpro viton (intake) seals are better than stock. I used 16 rather than use the hard plastic exhaust seals.
May 30, 2005 | 03:29 PM
I'm quite sure the LT1/4's are different than early C4's...either because of the aluminum heads or simply a change of seal layout.
The OEM's looks very similar to the Fel Pro that I've seen...they just pop on with a little plastic tool or...maybe a wooden dowel depending what you have available.
May 30, 2005 | 07:31 PM
Yeah, my CNC Heads have all black seals. With is the difference with the red seals?
Thanks for the part #'s, I'll pick up a set this week.
May 30, 2005 | 08:38 PM
Teflon valve seals?
Quote:
What's the problem with "teflon" seals? Please let me know before I put my engine together.
Thanks,
JTHVETTE
May 30, 2005 | 09:19 PM
St. Jude Donor '14
Quote:
Thanks,
JTHVETTE
They tend to deform with heat, they will not grab the guide and thus ride with the valve, rather than wiping the oil as intended. Useless !
May 31, 2005 | 01:34 AM
They also become brittle and fail, leaking oil into the exaust valve.
Just don't drop a valve into the engine
when changing them.
