HEI capacitor
Old Jul 13, 2005 | 10:02 AM
ULTM8Z's Avatar
ULTM8Z
Default HEI capacitor
Hi folks, new to the board.
Question: Has anyone here ever had the little HEI capacitor blow out? What were your symptoms (besides radio noise)? Did you figure out what caused it?
Engine is a MiniRammed ZZ4.
Thanks.
Old Jul 13, 2005 | 10:54 AM
VAHROOM's Avatar
VAHROOM
Though I haven't had this issue, I wanted to say welcome to the board. I would imagine if the capacitor did go open, it could cause radio noise and possible damage to the module from spikes it is supposed to supress.
Once again, welcome to the board.
Old Jul 13, 2005 | 05:49 PM
Dougs 90's Avatar
Dougs 90
Cant help you there but I have to ask, how do you like that miniram on the ZZ4?
Thanks,
Doug
Old Jul 13, 2005 | 10:17 PM
ULTM8Z's Avatar
ULTM8Z
Love the MiniRam. At least when the engine was running right.
Old Jul 14, 2005 | 09:48 AM
Dougs 90's Avatar
Dougs 90
Wich MiniRam are you using and what cam?
Thanks,
Doug
Old Jul 14, 2005 | 10:02 AM
tjwong's Avatar
tjwong
Thanks.
I was working for GM when the HEI system was introduced. Since then I have only seen on instance of that cap going bad. All that happened to that particular car was noise in the radio. In that case, the cap was just bad, it didn't physically come apart.
Old Jul 14, 2005 | 07:03 PM
ULTM8Z's Avatar
ULTM8Z
I've heard claims that the car won't run at all, all the way to that the car can run fine without it. Is there a way to test the thing to see if it's bad?
I'm running the MiniRam I with a comp cams 212°/218° roller and AFR 180 cc heads.
Old Jul 16, 2005 | 01:57 AM
Dougs 90's Avatar
Dougs 90
If I remember correctly that part is only $9. I replaced mine when I installed my MSD box.
To HEI capacitor
