Erection Problems...
Old Sep 15, 2005 | 08:54 AM
smacko's Avatar
smacko
Default Erection Problems...
I AM talking about my power antenna of course!
Have just cleaned up the inside of my power antenna, having finally gotten around to replacing the ribbon. Trouble IS, after following the AC Delco instruction sheet - I am now left with 'my mast at full erection'!
Going to be real difficult unless I can get it DOWN before I attempt to reinstall it!
My haynes doesn't have the schematic diagram for what I need for my '85's antenna; 3 wires coming FROM power antenna - need to know voltage of each wire - colours are:
grey
white
green
I know 2 will be 12v neg & pos and assume 3rd is the pulse trigger from stereo 'pwr ant' (Which is pink according to haynes), tho obviously changes colour somewhere down the line. I assume it is around 5vdc, but may be wrong.
Any joy?
My antenna & I thank-you in anticipation
Old Sep 15, 2005 | 09:10 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here you go..... http://members.shaw.ca/agent86/Power%20Antenna.pdf
Old Sep 15, 2005 | 09:12 AM
Stingraynut's Avatar
Stingraynut
Hey Smacko - considering your car is in a million pieces at the moment, I don't know how you get on without the GM service manuals!!!
I'm not sure you're gonna get that car back together again!!! but I hope so.
As you know, mine's an 88, my manual says there are 5 connections to the antenna motor - 3 come from the relay - white Green and grey - same as yours, then there is a braided strap going to ground at G400(I'd guess the chassis somewhere close) and there is the antenna coax lead going to the radio.
The three from the relay - green is the central wire to the motor and white takes the down power and grey the up.
I'm not the world expert on reading these diagrams, so please will someone else chip in and confirm or explain?
S'nut
rodj's Avatar
rodj
Mate ,the yanks are still in bed!
'87 service manual shows green as the common.
Gray+ / green- = Up
White + / green- = Down
Have factory service manual so email me any time
vetteoz@optusnet,com.au
Old Sep 15, 2005 | 09:15 AM
rodj's Avatar
rodj
Obviously , vette owners in Oz don't go to bed early.
Old Sep 15, 2005 | 09:17 AM
smacko's Avatar
smacko
Originally Posted by AGENT 86
Mate; you are wonderful!
THANK-YOU SO MUCH!
No wonder CF rules (AND is a whole lot cheaper than the GM manuals!) hehehe
Old Sep 15, 2005 | 09:20 AM
smacko's Avatar
smacko
S'nut
YEAH YEAH S'NUT: BAD enuff u bag me on emails let alone put up with your comments HERE too! hehehehe
PS; U should rename yourself here as just 'STING'; I think you KNOW why! Bzzzzzzz hehehe
Old Sep 15, 2005 | 09:21 AM
Stingraynut
Hi rodj - glad I read the manual right!
"Obviously , vette owners in Oz don't go to bed early."
I was just emailing Smacko and he's already gone out to see if it works!!!
S'nut
Old Sep 15, 2005 | 09:23 AM
smacko's Avatar
smacko
Gray+ / green- = Up
hahaha cheers mate!
(No, we have to stay up late to consult the corvette bible!)
Old Sep 15, 2005 | 09:24 AM
smacko's Avatar
smacko
S'nut
Yeah, right! I have the antenna right here in my office, along with half a c4 engine as you know!
Old Sep 15, 2005 | 09:27 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Mate here in QLD we are tough enough to go all night... and then some....
Old Sep 15, 2005 | 09:28 AM
smacko's Avatar
smacko
Originally Posted by Casethecorvetteman
Mate here in Australia we are tough enough to go all night... and then some....
I agree, tho as I get older I'm growing less fond of the title here 'senior member'...Just member would do!
Old Sep 15, 2005 | 09:31 AM
Casethecorvetteman
Well im only 24, [this week anyway] and im still senior!!
Old Sep 15, 2005 | 09:32 AM
smacko's Avatar
smacko
Gray+ / green- = Up
And cheers again Rod; I never thought of green being 'common'
Old Sep 15, 2005 | 09:45 AM
smacko's Avatar
smacko
Damn; just looking at that pdf file; looks like I may have not installed the drive gear in the right spot (Was wondering about that!) - did it according to accompanying leaflet which came with replacement ribbon, from Delco.
Out of curiousity too; the front bearing in mine is metal, as opposed to plastic as the file states...Maybe an upgrade ?
Old Sep 15, 2005 | 09:53 AM
smacko's Avatar
smacko
OLD more like it mate!
Old Sep 15, 2005 | 06:26 PM
GeosFun's Avatar
GeosFun
I have no idea how to fix the erection problem. I thought the label advised, if you cannot get it to go down after 4 hours, go see a doctor! Anyway, I had to read the string after the great title. BTW, you guys down under talk wierd. Do you actually understand what each other are talking about?
To Erection Problems...
Old Sep 15, 2005 | 06:29 PM
GeosFun's Avatar
GeosFun
Sorry, I got carried away.
Old Sep 15, 2005 | 08:28 PM
Stingraynut
Mate, no offence taken, you'd talk weird as well if your antenna was continuously erected !!
S'nut
Old Sep 15, 2005 | 08:45 PM
smacko's Avatar
smacko
hahaha - mate, I made the title that cause I needed a response FAST & knew it'd be a draw card!
We prob talk weird on this topic owing to most of us kind of knowing each other
