Differences between Cloyes timing chains
Old Nov 30, 2005 | 08:18 PM
  #41
mseven's Avatar
mseven
Originally Posted by sothpaw2
You just don't mesh a gear which is 41 RC with a gear that is 28 RC. In contact, the soft gear will wear. In my case, I think had something that acclerated the wear, but I bet that every gear will wear way faster then it should.
Thanks, and Yes I agree, I am not sure what their philosophy is knowing that themselves. I had thought about this, and their design (I also am not a believer in having the extra timing cuts in the crank sprocket, (hex adjust is good, and a crank sprocket specific), considered billet, but I thought at this point in the game I'm not seeing enough power for it be an issue, my concerns became allingment and degreeing.
This subject interested me because I had isssues w/crank sprocket alignment to cam sprocket, had several talk w/engineers at cloyes, and had to get some maching done (about .012 of crank sprocket for alignment, PIA), that is when I became aware of thier hardening etc.
