Differences between Cloyes timing chains
Old Oct 3, 2005 | 01:26 PM
TM-Z06's Avatar
TM-Z06
Default Differences between Cloyes timing chains
Doing a search on the forum yielded more than one part number, so before I ordered the wrong one, I thought I'd ask. Which Cloyes double-roller timing chain do I need for a Meizere HD electric water pump?
9-3145 $80
9-3151 $350
9-3157 $90
Old Oct 3, 2005 | 04:34 PM
500hp's Avatar
500hp
Use the 9-3145. But before you final assemble/silicone the timing cover to the block, turn the motor over several times to see if the chain rubs on the inside of the cover. Clearance the cover if necessary (it is usually the roller pins extending beyond the chain links that rub around the cam sprocket area on an LT1). Use a cut-off wheel on a straight die grinder (or air grinder) and walk it around in a circle.
Old Oct 3, 2005 | 04:48 PM
STL94LT1's Avatar
STL94LT1
I'm not 100% certain. But, you may have a problem running a Cloyes DR on a 96 with the reluctor ring.
Old Oct 3, 2005 | 05:33 PM
gslotman's Avatar
gslotman
9-3145 $80
9-3151 $350
9-3157 $90
Good question. I've got a 95 LT-1 and will be installing a Meizere (std) EWP. I figured as long as I was up on that end of the car I might as well eliminate the additional weight from the Cam sproket gear and buy a complete new set (no LT4 HD). Cloyes seemed to be correct choice
for Cam/Crank and chain.........I am all
Old Oct 3, 2005 | 05:34 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I have the 9-3145 in my '95. Don't use the standard Meziere, get the HD.
Old Oct 3, 2005 | 05:52 PM
Zix's Avatar
Zix
9-3145 $80
9-3151 $350
9-3157 $90
When you do a double roller in a '96 you will need to remove the crank sensor, it will not fit. You can have the crank sensor programmed out of the computer so it does not trip any codes.
Also, when ordering from Cloyes, do NOT get the 9-3145A, that timing set will not work, only the 9-3145!
Old Oct 3, 2005 | 05:56 PM
TM-Z06's Avatar
TM-Z06
OMG!!! I sure dont want to hear that. I checked out Summit Racing, and 9-3145 did not match my car. However, 9-3157 was a match so I ordered it.
CLO-9-3157
Make CHEVROLET
Engine Type V8
CID 350
Liter 5.7
Engine Size 5.7L/350
Beginning Year 1992
Ending Year 1997
Engine Family Chevy small block Gen II (LT-based engines)
Notes: Requires the use of an eletric water pump for installation.
Old Oct 3, 2005 | 06:10 PM
Zix's Avatar
Zix
CLO-9-3157
Make CHEVROLET
Engine Type V8
CID 350
Liter 5.7
Beginning Year 1992
Ending Year 1997
Odd, I'm not seeing that part number in the Cloyes catalog?
Old Oct 3, 2005 | 06:21 PM
TM-Z06's Avatar
TM-Z06
From Summit Racing
Tell me what you think.....
Old Oct 3, 2005 | 06:43 PM
FD2BLK's Avatar
FD2BLK
I think you need another timing chain. THe only option you have if you want to keep the reluctor ring and CPS other then stock is the HD LT4 set as far I as I know. Some one did some crafytu machine work a while back and was able to get the reluctor ring to work with a standard DR timing set but it was a lot of work from what I remember.
Old Oct 3, 2005 | 07:21 PM
TM-Z06's Avatar
TM-Z06
If my guy can't get this Cloyes to work, then I'll have to order the GM unit.
Old Oct 3, 2005 | 07:36 PM
Zix's Avatar
Zix
If you want the double roller and you can't get that one to work, just order the 9-3145, that is what I am running in my LT4
Old Oct 3, 2005 | 07:49 PM
TM-Z06's Avatar
TM-Z06
Zix - are you running an electric water pump?
I wonder why Summit Racing's website does not show 9-3145 as a match for the GenII (LTx) engine?
CLO-9-3145
Make CHEVROLET
Engine Type V8
CID 350
Liter 5.7
Beginning Year 1985
Ending Year 2000
Old Oct 3, 2005 | 07:58 PM
aboatguy's Avatar
aboatguy
Great thread I was getting ready to ask this question!!
This means I can buy an electric water pump and timing chain for about the same money I did not spend on the Kent Moore harmonic balancer puller!
Old Oct 3, 2005 | 08:01 PM
Zix's Avatar
Zix
Yep, I am running the Mez HD electric pump.
Well, Summit might not show it because it really isn't a perfect fit because you do need to remove the crank sensor for it to fit. Cloyes lists the 9-3145 as a fit for '85 and up roller blocks...not specifically for the LT1.
Old Oct 3, 2005 | 08:22 PM
TM-Z06's Avatar
TM-Z06
Hmm - if that's the case.... 9-3157 should work for me - since it's supposed to be designed for the LTx motor.
Old Oct 3, 2005 | 08:27 PM
Zix's Avatar
Zix
Post your results, I'm very curious how it works! When I ordered mine I was on the phone with Cloyes and they told me they didn't have any double rollers that were specifically for the LT engines!
To Differences between Cloyes timing chains
Old Oct 3, 2005 | 08:43 PM
Baldturbofreak's Avatar
Baldturbofreak
I used the cloyes billet hex adjust for 86+ blocks with no problems
Old Oct 3, 2005 | 09:02 PM
Zix's Avatar
Zix
The hex-adjust won't work on an LT block though because the cam pin needs to be free to spin the Opti, but the hex-adjust sets have the adjuster covering the pin so it won't fit into the optispark.
Old Oct 4, 2005 | 12:54 PM
sothpaw2's Avatar
sothpaw2
CLO-9-3157
Make CHEVROLET
Engine Type V8
CID 350
Liter 5.7
Beginning Year 1992
Ending Year 1997
This is what Cloyes told me to use so I hope it works.
