code 42 help?
Old Dec 9, 2005 | 02:59 AM
brogden31's Avatar
brogden31
Default code 42 help?
This code is for ign. so does anyone know the resistance for the coil or how to check ign module or the starting point to diagnose a code 42
Old Dec 9, 2005 | 09:33 AM
MBDiagMan's Avatar
MBDiagMan
The big question is; does the car start and run. If so, don't worry about the coil itself for now. You probably have a wiring problem between the distributor and the ECM.
Hope this helps,
Old Dec 9, 2005 | 10:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2042.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
To code 42 help?
