'85 headlights won't open?
Old Dec 13, 2005 | 07:01 PM
stormin310's Avatar
stormin310
Default '85 headlights won't open?
Good friend just bought a '85 turns on headlight switch they don't open..... opens hood and the lights are on any help would be appreciated ..................
Old Dec 13, 2005 | 07:07 PM
steveb's Avatar
steveb
Are the motors making any noise at all when he turns on the lights? If not, power might not be getting to the motors. Trace the wires back from the headlight motors and make sure they are not damaged and that they are plugged in securely.
--sb--
Old Dec 13, 2005 | 08:03 PM
stormin310's Avatar
stormin310
--sb--
I emailed him this response he didn't say it made any noise at all and will have him check the wiring etc but both headlights isn't there a common fuse or something?Kinda unlikely both motors suddenly went out
Old Dec 13, 2005 | 08:17 PM
stormin310's Avatar
stormin310
We are both electronics technicians is there a good place to check voltage that would affect both???
Old Dec 13, 2005 | 08:35 PM
steveb's Avatar
steveb
I have a schematic diagram from my 85 Helm's manual if that will help. Let me know and I will e-mail it to you.
--sb--
Old Dec 13, 2005 | 08:51 PM
stormin310's Avatar
stormin310
--sb--
Sure thanks wasn't sure if its different from my '96 stormin310@aol.com
Old Dec 13, 2005 | 08:56 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Dec 13, 2005 | 11:07 PM
stormin310's Avatar
stormin310
Thanks Steve this guy is sharp he will isolate with the schematic..
Old Dec 14, 2005 | 08:33 AM
steveb's Avatar
steveb
Direct him to that link Agent86 posted if he gets stuck. Looks like there was some good troubleshooting procedures listed as well as the schematic.
--sb--
Old Dec 14, 2005 | 08:39 AM
RacerX70CC's Avatar
RacerX70CC
Check to see if the isolation relay and/or headlamp relays have power and grounds. The relays are located in the LH front wheelwell under a cover held on by 2 7MM bolts.
Good luck!
Old Dec 15, 2005 | 09:24 AM
stormin310's Avatar
stormin310
ttt having my friend read thread...he's a newbie...lol
Old Aug 28, 2019 | 04:52 PM
Vincent Boggess's Avatar
Vincent Boggess
1st Gear
Default Headlight issue
--sb--
I was reading over this and seen you have a diagram
Would you be able to send that to me please?
Vboggess89@gmail.com
Old Aug 28, 2019 | 07:31 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Sorry, Vincent, but this guy hasn't been seen in 14 years. He's probably not going to respond.
If you have a problem, you need to start a new thread, not respond the Zombie!
To '85 headlights won't open?
