Engine temp getting down between 140-150F on highway. Why??
Old Jan 4, 2006 | 07:23 AM
darkman5001's Avatar
darkman5001
Default Engine temp getting down between 140-150F on highway. Why??
I had my chip tuned along with a 180F thermostat so the engine runs a little cooler. It worked great for quite a while. But now lately, the engine coolant temp gets down to around 142F on the highway, which is the lowest I have ever seen it get. I know the computer has got to be going into open loop at that temp (maybe I am wrong), but is there somewhere I can start looking that might be a possible problem? Anyone else have this problem. As far as idling or normal driving, the temp stays between 170-195F usually. Thanks!
Old Jan 4, 2006 | 07:34 AM
Pete K's Avatar
Pete K
Your thermostat may have stuck wide open. I suggest changing it. Usually they slam shut at some point. Overheating then happens.
Old Jan 4, 2006 | 08:23 AM
HeeHaw89's Avatar
HeeHaw89
Mine does the exact same thing...I'll be pulling/testing the thermostat.
Old Jan 4, 2006 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Mine goes closed loop at about 135 so there is a good chance your still in closed loop.
Old Jan 4, 2006 | 08:46 AM
HeeHaw89's Avatar
HeeHaw89
I'm assuming that closed loop is occurring when my convertor locks up.?
It locks up right around 125 on the gauge, which I believe is more like 130.
When I had a scanner hooked up the ecm was seeing +5deg more than the gauge was showing.
Old Jan 4, 2006 | 10:00 AM
Slalom4me's Avatar
Slalom4me
It is also possible that the sensor has gone bad.
But under the circumstances reported, the thermostat is my primary
suspect, too.
The coolant level is up, right?
Try posting in C4 Scan & Tune to determine if or when coolant temp
signals open loop. HeeHaw89, ditto for the interaction between C/L
and the converter locking up.
Old Jan 4, 2006 | 11:29 AM
tjwong's Avatar
tjwong
Is that the indicated temperature on your dash? You should scan the ECM and see what it is seeing for a temperature. There are two sensors, one for the ECM and one for the dash instruments.
Old Jan 4, 2006 | 11:46 AM
CFI-EFI's Avatar
CFI-EFI
It is my experience that there are two different types of thermostats. Those that fail open and those that fail closed. Unless your gauge is reading incorrectly, and the 170° to 195° at idle and cruise indicates that it's working, there is no question that your stat isn't closing. I wouldn't worry about it closing on you, but it needs to be changed, A.S.A.P.
RACE ON!!!
Old Jan 4, 2006 | 11:57 AM
MBDiagMan's Avatar
MBDiagMan
Replace the thermostat with a fail open type such as the MotorRad.
It is VERY unhealthy for your engine to have low temperature especially in the winter time. It leads to lots of gunk and acids in the crankcase because the moisture is not boiled out of the oil.
I would also change oil when I change the thermostat.
Good luck,
Old Jan 4, 2006 | 12:19 PM
vader86's Avatar
vader86
I suspect the coolant temp sensor, even with a stat malfunction the coolant should not be able to maintain those temperatures.
Old Jan 4, 2006 | 12:26 PM
pwrful c4's Avatar
pwrful c4
I had the same problem,it was temp sensor.
Old Jan 4, 2006 | 12:52 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
I aggree, it would have to be damn cold out to support that
Old Jan 4, 2006 | 01:00 PM
Nathan Plemons's Avatar
Nathan Plemons
But not impossible. If the engine is turning relatively low RPM's, such as at highway speeds, and you have a lot of airflow through the radiator, such as at highway speeds, and you have cold temperatures, such as in January.
Certainly wouldn't hurt to check. What's a thermostat cost, $5?
Old Jan 4, 2006 | 01:54 PM
crheinish's Avatar
crheinish
your coolant temp sensor is bad or your thermostat is stuck open.
Old Jan 4, 2006 | 02:12 PM
Nathan Plemons
Does the temp gauge tend to read what you would expect around town and only drop when on the highway? If so then I'd say you can rule out the sensor.
Old Jan 4, 2006 | 02:16 PM
CFI-EFI's Avatar
CFI-EFI
In New Jersey? In January? With a newly reprogrammed prom to turn the fans on earlier? *I* think so. I normally advocate testing everything, before replacing it. However, a test won't be needed, here. If you pull the stat out and it is wide (or even a little) open, you have your answer. If not, TEST your thermostat AND ECT sensor. My car runs a constant 178° on the highway at anything over 50 mph in 40° ambient temperature air, with a 180° thermostat, with no fan. I sometimes wonder how low it could go. I really should stick that 195° stat in there for the winter.
RACE ON!!!
Old Jan 4, 2006 | 03:52 PM
rlane5's Avatar
rlane5
Darkman,
Is your cooling fan on all the time while you are driving? My vette will go down to 155-165 while on the highway this time of the year but on the street it runs normal and I live in Jersey also.
Randy
To Engine temp getting down between 140-150F on highway. Why??
Old Jan 4, 2006 | 04:02 PM
Nathan Plemons
VERY low. I had a '91 cutlass that the thermostat decided to stick open on one night when it was 20 degrees outside. The car didn't have any kind of temp gauge, but I know my heater didn't work at ALL, it was absolutely ice cold, mean it physically hurt your hands to hold them in front of the vent for any length of time.
Now if I let the car idle for a long time it would actually heat up, but the instant there was any airflow across the radiator it would go right back to ice cold.
The radiators on most cars are actually, for lack of a better term, "over efficient" and perfectly capable of plunging the operating temperature well below the ideal point, hence the reason for a thermostat in the first place.
A friend of mine had an LT1 that the thermostat stuck open on. I drove that car from his house to mine one night when it was about 12 degrees out. I drove 5 miles at highway speeds and when I got to my house I popped the hood and was able to place my hand right on the intake. Not only was it not hot, it was still ice cold.
Old Jan 4, 2006 | 09:50 PM
HeeHaw89's Avatar
HeeHaw89
As a follow up to my post #3 above, I pulled my thermostat tonight and it was stuck open. Not all the way, but it was definately open.
I threw it in boiling water and it opened wide but after pulling it out it stayed open maybe1/3 of the way, just as it was when I pulled it out of the car.
Also if you are still unsure of your temp gauge accuracy, compare it to your oil temp reading. They are usually fairly close, with the oil running a little hotter.
Old Jan 5, 2006 | 12:46 AM
kopbet89c4's Avatar
kopbet89c4
I had this exact problem months ago and it was a failed t-stat stuck in the open position. Its better for it to get stuck open than closed and burn up your motor.
