Post your hp and ET...
Could you post your RWHP, ET and MPH if you know them?
Oh and tranny too.
Thanks in advance.
-Mike
However at the risk of sounding ignorant, lots of times the two do not match very well - which is topic of debate many times through the year on this forum.
I am going to request in the near future a submital of combinations for selection and posting, similiar to what BeachBum had on a website that was a collection of some of the best COMBOs for corvette for performance.
However lets see what you turn up here in this post. Should be interesting. My bet is you get a BUNCH of HUGE hp claims that don't even come close to matching the ET/MPH they should be running.
Hint, you should also ask for race weight. That has a HUGE bearing on the ET you can run with a given HP.
Here are mine to start things off.
406 MOTOR:
11.02@123 MPH 1.49 60' times. 436rwhp/536ft-lbs (dyno on website in sig below as are more specifics to this combo)
pro-built 700r4
434 MOTOR:
10.15@134.9MPH 1.37 60' times. Estimated 600HP
pro-built 700r4, Rossler Turbo350 (no appreciable diffence between the two)
race weight for both cars 3400 lbs
12.732 @ 115.87
379.9 RWHP @ 6160 RPM
356 RWTQ @ 4100 RPM
6-spd manual, 3.45 rear, street tires
My best time ever was a 12.97 and my best mph was 109.29.(not on the same run).
Stock LT1 six speed with Michelin Pilot XGT Z4 tires in the stock sizes.
-2500 DA
305 RWHP. 12.92 @ 108.5. 6-speed, stock weight, plus my 180lbs.
With my Nova
480 CHP. 11.31@117. TH350, 3800 RPM Stall. 3600lbs with me in car.
I know what my motors make and are capable of making based on TONS of research comparing to other setups and comparing HP numbers from very reputable engine builders.
Comparing my 406 that ran 123MPH with 436rwhp, you can quickly see that others stating near the same HP are nearly 10mph off even with manual boxes (usually produce 3mph higher MPHs).
That is why I say if you want to find your USEABLE HP rating of your car, take it to the track and on the return road, stop in at the scales, get a good weight of your ride, and go home and calculate how much your using.
At the end of the day, it doesn't matter how much you claim to have, its how much your able to effectively use or how well you put to work what you only have.
That is the name of the game. I will take a "low" HP rating anyday to have a good usable MPH. Unfortunately once you completely understand what is going on, you need HP to make MPH.
As more post, you will see however that you can have high HP numbers and not even come close to the respective MPH. That statement may be confusing to some, but read it a few times and pay attention to the information being posted - it will become more clear.
(however, best dyno was 362 rwhp, but that was a year earlier)
Jesse's biggest argument always seems to be that people with high horsepower numbers don't seem to run the track times that they "should." At that though you have to determine how what a car "should" run was determined. Is what a car "should" run based off of a car with sticky tires, a loose stall, shoft shocks in the back, etc, etc. Horsepower is only part of the story, the combination has to be optimized to apply that power in an effective manner for the intended purpose.
The only way that you can really get a good correlation between HP and track times is if you can hold all of the track conditions and car conditions constant. Vette's aren't F-bodies. Although they both may make the same horsepower, they can have radically different track times simply because they have different drivetrains, weight characteristics, drag coefficients, etc, etc, etc.
Jesse always tells us that people get too hung up on dyno numbers, and that dyno numbers don't always mean faster track times. He's absolutely right in that regard. However, a more powerful (referring to total power under a dyno power cureve) car, makes more power. That says nothing about if that power can effectively be utilized for one application or another. It simply depends on what your goal is. Do you want an extremely powerful street car that handles like it's on rails and has a crazy top end speed or do you want a mushy suspension drag car that uses every last drop of it's power to accelerate from 0 to a quarter mile and then do nothing else?
Neither answer is "wrong," but it leads to a bunch of argument that really just needs to stop. It never goes anywhere because both sides are "correct" provided you stick with the restrictions that each side presents. The issue in this argument always comes in when one side decides to ignore the restrictions that the other side places.
At least thats all I ever meant.... dyno's are fun and in many, many cases very accurate.... but not always.
cheers,
Beach Bum
cheers,
Beach Bum
