Scan codes
Old Mar 8, 2006 | 11:20 AM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Default Scan codes
Question here. May have been covered before, but need fairly quick answer. The 1996's have OBDII right? If so (and I think this is right), which pins do you jump to read the codes for SES light?
All OBDII should be the same? Thanks.
Old Mar 8, 2006 | 11:26 AM
teebee's Avatar
teebee
OK, after running a search I found a thread in which Bogus answered the question. It can be done, but too difficult to decipher the code. Thanks anyway.
Old Mar 8, 2006 | 11:31 AM
rick lambert's Avatar
rick lambert
Thought you needed a scan tool for the OBD-II systems, it's much more complex than the OBD-I. Could be wrong.
Old Mar 8, 2006 | 03:26 PM
teebee's Avatar
teebee
Yea, Rick you are right, it's too complex.
Old Mar 9, 2006 | 05:36 AM
CJB's Avatar
CJB
1995 was the last year you could jump pins 4 & 12. Up until that point (1994 - 1995) it was OBD I, in a 16 pin shell. You got to have the OBD II scanner....no doubt about it.
To Scan codes
