Service Engine Soon - Code 54?
Old Apr 4, 2006 | 03:35 AM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Default Service Engine Soon - Code 54?
The '86 is havin some problems lately starting up after sitting for a while (a while being overnight / most of the day); it will take a good 5-10 seconds of cranking before the car will start up and run, but after that it runs fines and will start back up with no problem, even after sitting for a few hours. The Service Engine Soon light comes on and stays on after it has a start-up problem, but any time it starts up without a problem the light does not come on. It spat out a code 54 when I put it in diagnostic mode, but my shop manual for the car doesn't list that code.
It's been suggested to me by a friend that the Cold Start Valve may be having a problem, which is always a possibility. (... and if this is likely the case, how much would replacing it probably cost?)
.... help~
Old Apr 4, 2006 | 04:44 AM
86PACER's Avatar
86PACER
Code 54 is the fuel pump circuit.
Use this site.
http://corvettebuyers.com/c4vettes/ecm.htm
Old Apr 4, 2006 | 04:47 AM
86PACER's Avatar
86PACER
By the way, Code 54 is covered on page 6E3-A-68 of the 86 GM Shop Manual.
Old Apr 4, 2006 | 04:55 AM
86PACER's Avatar
86PACER
Are you missing that section of the manual?
Old Apr 4, 2006 | 09:49 AM
rick lambert's Avatar
rick lambert
fuel pump circuit-most likley a bad fuel pump relay-this would account for the addtional cranking too. Do you hear the pump prime when you first turn the key to the on position? if not-most likely the relay OR
the wires entering the relay-alot of us guys have inspected those wires-just to see the insulation has shrunk back exposing bare wires!
Old Apr 4, 2006 | 09:11 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2054.pdf
To Service Engine Soon - Code 54?
