A/C Inop
Old Apr 4, 2006 | 04:27 PM
STL94LT1's Avatar
STL94LT1
Default A/C Inop
How to diagnose the problem? Compressor? Clutch? Something else?
Old Apr 4, 2006 | 04:33 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Okay, what exactly is not happening?
Something as simple as low refrigerant can prevent the compressor from coming on....
Larry
code5coupe
Old Apr 4, 2006 | 04:36 PM
STL94LT1's Avatar
STL94LT1
Freon is fully charged. Just sounds like the clutch is not engaging.
Old Apr 4, 2006 | 04:42 PM
rocco16's Avatar
rocco16
Well, start the car, turn the AC on, lift the hood, and see if the compressor is spinning.
...that would be the first step.
Larry
code5coupe
Old Apr 4, 2006 | 04:52 PM
SunCr's Avatar
SunCr
And if it's fully charged, check the connection at the Low Pressure Switch. If it's come loose, it won't run - in fact wriggle it around to make sure you don't have an intermittent. Also, disconnect and reconnect the battery to remove any a/c trouble codes from memory. If it comes on, any trouble code should reset.
Old Apr 5, 2006 | 01:07 AM
93*Corvette's Avatar
93*Corvette
Goto the top of the forum and look at Other, Tech Tip, C4, and look at HVAC Diagnostic code translation 90-96 Here is the link....
https://www.corvetteforum.com/techti...=193&TopicID=2
Old Apr 5, 2006 | 10:27 AM
tjwong's Avatar
tjwong
Mike do you have the diagrams? I can send them to you.
Old Apr 5, 2006 | 10:47 AM
MrNuke's Avatar
MrNuke
Mine isn't working either, but it says it's low on freaon, and the car was already converted to 134. I'll have to refill it and see if it has a leak or somewhere...
Old Apr 5, 2006 | 10:52 AM
Jerris's Avatar
Jerris
Make sure you disconnect the battery after filling it with freon to erase the codes.
The AC will not reset itself and the CCM will not turn on the AC if the codes are not erased.
Old Apr 5, 2006 | 10:59 AM
MrNuke's Avatar
MrNuke
Wow didn't know that... Thank You.
Old Apr 5, 2006 | 09:25 PM
93*Corvette
I didn't know that either.... Thanks again Jerris....
To A/C Inop
