Well its ON now.
Old Apr 8, 2006 | 03:20 AM
Gold1986Vette420's Avatar
Gold1986Vette420
Default Well its ON now.
I have a grudge match with my friend who has a 405 SAE RWHP (DYNOJET) (soon to be 430+ RWHP) LS1 Camaro. he has forced me to make the Following changes to my car:
Full 3" mandrel bent exhaust with XPIPE, no Cats, and Race style MufflersDynomax Ultraflows.
Full Reverse Manual Valve Body no auto option.
Convert to Accel DFI gen 7+ and ditch the Restrictive MAF.
It will be setup and tuned by Matt of TT Performance in Clifton NJ. They are Great!
Question is: Will I be able to beat him?
We both have 4 speed autos and 3.73's. He is putting down 405 RWHP and 365 RWTQ through the Auto and he has a 4000 converter and DR's.
My setup:
1976 400 2 bolt Block bored and stroked to 420 Cubes.
11.28:1 compression.
Eagle 4340 rotating assem, w/ 6" H Beam rods and Custom JE forged pistons w/ 1.06" compression height. (very light and short skirt)
TPIS Miniram ported and cleaned up. 1000 CFM TB.
AFR 210 cc RR heads,milled, cleaned up, w/ spring upgrade for .700+ lift
TPIS 700-702 Cam 248,248 @ .050 w/ .659,.661 lift w/ 1.6 RR
Block Decked and Align Honed, w/ everything balanced.
TPIS 1 3/4 headers with the 3" exhaust coming soon.
TPIS Cold Air under the nose w/ K&N
Dynamic 700r4 with the reverse manual going in it soon.
TCT 3400 10" non-lockup converter
Dana 44 w/ 3.73's
315/35/17 BFG DR.
Anyone have a clue what kind of power to expect?
He thinks he will be low 11's in his car and I am hoping for the Same.
Please let me know what you guys think.
I am dropping the Car off at TTP on the 15th.
Old Apr 8, 2006 | 05:10 AM
comp's Avatar
comp
sounds like a race to me
Old Apr 8, 2006 | 08:45 AM
rick lambert's Avatar
rick lambert
Probably depend on where the power curves come in-you know what cam he's running-no matter, the race is on and I'm putting my 6 pack on you by a breath
Old Apr 8, 2006 | 12:40 PM
SJW's Avatar
SJW
Who's the better driver?
Be well,
SJW
Old Apr 8, 2006 | 01:30 PM
Gold1986Vette420
Default Driver's Race?
He has been known to sleep at the tree.
My Car is at least 100+ lbs. lighter than his.
I have logged 500+ passes on the Vette and the last full year (sadly back in 2000)out averaged .096 reaction time, but that was the old 350 combo. It will take a while to learn the new setup and traction.
I think it will be decided by the tree and more importantly traction levels.
How much RWHP should I expect with a non lockable converter?
I am expecting at least 60+ ft/lb advantage over him. (mainly the cubes and compression).
I will keep you guys posted to where it actually dynos when it tuned.
Hopefully they will get me in and out quickly.
Dropping it off next weekend april 15th.
Old Apr 8, 2006 | 02:07 PM
lcvette's Avatar
lcvette
if your car is tuned and running properly and your a 100lbs lighter and you don't beat him you need to start another hobby like ballet dancing.. your car should be putting close to 450-500 at the wheels with that cam heads and cube setup.. this is presuming your engine is running like it needs to and your fuel system is in place and you have the tune dead nuts on.. sounds like you should be punishing this guy!
Chris
Old Apr 8, 2006 | 02:10 PM
blown87's Avatar
blown87
GA Events Coordinator
My money is on you.
Old Apr 8, 2006 | 07:24 PM
Gold1986Vette420
Thanks for the support fellas. I am hoping to whoop his ACE.
Anyone else out there have anything similar to mine?
If so what does it run?
Old Apr 8, 2006 | 07:32 PM
Gold1986Vette420
Chris
Is that even possible with an unlocked converter with my setup?
I am not getting my hopes up.
I was told 552 HP and 560 torque on a 10.6:1 compression 406 that TPIS Dyno'ed with the exact same Heads, Cam, and Intake. Keep in mind they ran No accesories and open headers on an engine dyno. I am sure there is over 120 hp loss at the wheels with everything bolted up and an unlocked automatic. They thought I would't make any more HP but possibly a bit more torque due to the increase in cubes and compression. I guess the untouched AFR 210's only put out about 550 hp and thats the limiting factor.
Old Apr 8, 2006 | 09:44 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Originally Posted by blown87
My money is on you.
Old Apr 8, 2006 | 10:33 PM
bjankuski's Avatar
bjankuski
You should bre able to run high 10's with that combination. My car is less radical then yours and I am low 11's hoping for 10's. You should win.
Old Apr 8, 2006 | 11:03 PM
Gold1986Vette420
I checked your signature and your car is awesome. I just hope to run those numbers. I am asuming your converter was unlocked when dynoed. I always gear myself up for disappiontment so 10's aren't on my mind. I just want a clean pass down the track.
Good luck on your quest for the 10's.
Old Apr 8, 2006 | 11:05 PM
Gold1986Vette420
Was your car dynoed on a mustang or dynojet dyno? I am really curious.
Old Apr 9, 2006 | 09:12 PM
Gold1986Vette420
bjankuski
CF Senior Member Signature
1986 Coupe, auto, 3.45 gears, 1973 406, 11.5 to 1 compression, SLP cold air, gutted MAS, 58 MM throttle body, ported plenium, Superram intake, TPIS BASE, 23 degree Trick Flow Heads, ZZX cam, TPIS headers, TCI 3000 stall, 3" duel exhaust, Cheap and easy free mods, custom chip, daily driver
RWHP 405 @ 5400 RWTQ 436 FTLBS @ 4000
Best run
60 ft = 1.536
1/8 = 7.116 @ 95.874
1/4 = 11.185 @ 121.04
Is that a dynojet or mustang dyno?
Old Apr 9, 2006 | 09:23 PM
Gold1986Vette420
Re: YOU ARE GETTING SMOKED!!!!
U know, since you keep asking board members who is going to win... That shows you are getting scared !! Get ready to get SMOKED **** .... You R going down !!!
This was left on my private message. I cant wait to smoke him.
Old Apr 9, 2006 | 11:17 PM
bjankuski's Avatar
bjankuski
Originally Posted by Gold1986Vette420
bjankuski
Best run
60 ft = 1.536
Dynojet
Old Apr 9, 2006 | 11:23 PM
Gold1986Vette420
Dynojet
Thanks, I think Things are looking up for me.
BTW. Was the converter locked or unlocked?
To Well its ON now.
Old Apr 9, 2006 | 11:30 PM
bjankuski's Avatar
bjankuski
The numbers were with a locked converter. When the converter was unlocked my peak HP dropped to 376 RWHP and my peak torque increased to 490 RWTQ. The unlocking of the converter gives strange dyno numbers so I always dyno both ways to see what the engine is doing and then how the converter effects the output.
Old Apr 13, 2006 | 04:30 PM
javaradd's Avatar
javaradd
2nd Gear
I have no faith in your driving skills !!! The Z28 will take you !!!
Old Apr 13, 2006 | 08:59 PM
javaradd's Avatar
javaradd
2nd Gear
