It's alive!
Old Apr 14, 2006 | 04:51 PM
aboatguy's Avatar
aboatguy
Default It's alive!
Yesterday I completed phase 3 of my C4 mods.
AI 190CC full CNC ported heads, a cam in the 23X 0.57x neighborhood and all of the supporting OH BUY the ways!
It started right up. It idled like crap at the beginning but now it will sit in gear with the AC on w/no problems.
The CC Promags are noisier than I expected, I redid the lash a couple of times and did not shut it up. Today I went to a local shop and the tuner said, "You have the lash right, thats how CC promags sound!"
Once I get this puppy dialed in I'll take it to the dyno and see if it ends up being my daughter's drive to school car.
It sounds pretty good! My neighbor came by and commented that he could not hear his Harley over my idling car.
Mike
Old Apr 14, 2006 | 04:55 PM
rick lambert's Avatar
rick lambert
sure is pretty-let us know how you got it to idle without the intake
Old Apr 14, 2006 | 08:22 PM
aboatguy's Avatar
aboatguy
Sorry I had to rinse off the OPTI
Old Apr 14, 2006 | 08:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sweet! Nothings funner than hearing your motor fire up after a cam swap!
Old Apr 14, 2006 | 08:35 PM
Pete K's Avatar
Pete K
I hate to be the voice of doom, but I saw something unusual. It appears that the springs are sitting directly on the valve shims. If that is the case, the gold shims are not hardened and will shed alot of metal in your oil. Just thought I would mention it. If the springs are on seats and I just did not see them, disregard my post.
Old Apr 14, 2006 | 09:34 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Looks good. I thought I was the only one **** enough to line up the paint marks on the valve springs!
Old Apr 14, 2006 | 09:55 PM
aboatguy's Avatar
aboatguy
Nope they are lined up like that on every AI head that I've seen.
Best thing is that the intake goes on with out slotting and finagling the bolts like guys have to do with another respected porting company.
Mike
Old Apr 15, 2006 | 12:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Looks good
Old Apr 15, 2006 | 02:28 AM
STL94LT1's Avatar
STL94LT1
Can't wait to see the results.
Old Apr 15, 2006 | 06:42 AM
95NOSvette's Avatar
95NOSvette
Reguardless of whether the porter surfaces the intake port side of the head Like AI does....Most LT1 heads even after a 30thou cut, and on top of it, going to 26thou thickness head gaskets(instead of the stock 49 to 50thou ones).....still don't have to have the intake bolt holes elongated at all.......I just did Lloyd Elliots heads and cam with the above(aprox 55thou) thickness changes, and the intake went on perfect with no slotting or anything...matter a fact the intake port to head port alignment was even spot on.....another friends was the same way.......It all depends on the motor from the factory by the way your heads look awesome.I hope it runs well for you.....Joe
Old Apr 15, 2006 | 02:38 PM
aboatguy's Avatar
aboatguy
I was not disparaging Lloyd's work; in fact I was within hours of ordering a LE package. However, if you read some of the more performance oriented websites there are plenty of threads with intakes that will no longer fit, even with slotted holes after head porting/decking .
Old Apr 15, 2006 | 02:41 PM
aboatguy's Avatar
aboatguy
I contacted Phil and to paraphrase his response the springs are on machined & hardened locators and those gold "shims" are hardened.
Mike
Old Apr 15, 2006 | 02:42 PM
ScaryFast's Avatar
ScaryFast
I hate you.
Mine still doesn't run...
In all seriousness, though, congrats! Can't wait to see the dyno numbers.
Old Apr 15, 2006 | 02:58 PM
Pete K's Avatar
Pete K
Mike
Just trying to help. Last motor I saw that had the springs directly on the gold shims, with no spring locators, put enough metal in my oil that it looked like I was panning for gold when the oil was drained. sami85l98 had the same gold shims directly under his springs(with no locators) and it wore almost completely through a few of them in only a few thousand miles. Locators (seats) are always hardened. Yours are black, and I didn't see them because of the color.
Old Apr 15, 2006 | 02:59 PM
C4driver99's Avatar
C4driver99
Very nice!!
Old Apr 15, 2006 | 03:46 PM
Corvette Kid
I'm so glad that I've obtained zero decking on my new block with no cutting of the block. Thanks to CFI-EFI for that great idea.
Good catch, it did appear as though it could have been that way. That's what we're here for is to help each other and hopefully prevent unnecessary grief. Panning for gold, I like that!
Old Apr 15, 2006 | 03:49 PM
Pete K's Avatar
Pete K
I was ready to puke when I saw it. The gold glitter looks just like bearing material. Very little gold sheds with hardend spring seats.
To It's alive!
Old Apr 15, 2006 | 04:15 PM
aboatguy's Avatar
aboatguy
Originally Posted by ScaryFast
I hate you.
Don't be hatin'
My install had a couple of hiccups and took longer than planned and I am not 100% yet.
Old Apr 15, 2006 | 04:18 PM
aboatguy's Avatar
aboatguy
Pete I was glad that you were looking out for me. I shot an email to AI IOT get the skinny.
Mike
Old Apr 15, 2006 | 04:19 PM
aboatguy's Avatar
aboatguy
When's that puppy due to hit the streets of NC?
