Hedman hedders - hooker headers, size?
Old Apr 22, 2006 | 08:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by Nico
The fact that the port fitment is not considered a problem is a relief to me. Thanks for that info. Glad that it isn´t smaller wich should be worse.
AGENT 86
Please measure the center - center with between the hedder connections to the Y when the car is up. That may help me to find a Y
Will do
Old Apr 22, 2006 | 10:42 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by CFI-EFI
For what it's worth, it is perfectly acceptable for the port in the header to be larger than the port in the head.
RACE ON!!!
In fact, that's generally considered to be a good thing. It adds some anti-reversion effect.
Old Apr 22, 2006 | 10:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
Absolutely, most peple arent aware of this.
Old Apr 25, 2006 | 09:24 AM
Aaron's 87's Avatar
Aaron's 87
Header port size is not much of an issue when the headers are bigger than the heads, but the Elites (the thicker wall, coated, no emissions version in my case) came to me with a 1.2 x 1.4 port. My heads are ported 128s, but the ports weren't enlarged much. In fact, when I asked about port size when I noticed this problem, most on this forum agreed their stock 128 port size was greater than 1.2 across. So get the exact port size measurement of the headers before you buy. BTW, I asked before I bought the headers and Summit gave me the wrong dimensions. They gave me the 1.5 round dimension featured on the thinner wall, uncoated version of their headers.
To clarify, P/N 68448 came to me with 1.4 x 1.2 header ports which is SMALLER than my head ports. P/N 68440 has 1.5 round ports which works OK.
Old Apr 27, 2006 | 09:53 PM
AGENT 86's Avatar
AGENT 86
AGENT 86
Center to center they are 19 3/8"
I cut back the stock "Y" and will weld on the collector flanges and i'm done.
I did encounter a problem with the wiring harness on pass side and will have to reroute it a bit to avoid a meltdown.
Old Apr 27, 2006 | 10:31 PM
Corvette Kid
I knew that the Elites were an oval port but had never seen any measurements on them before. I did know that the standard Hedmans were 1.5" round as I've dealt with them before. That measurement on the Elites seems awfully small. What do your's measure, Dan?
Old Apr 27, 2006 | 11:08 PM
qws's Avatar
qws
I have the hedmans on mine, which is an 84. I ended up replacing the front y since I was already under there. Then I looked at the cat and said to myself, hell might just well replace that too. The front y, I just used a stock replacement , cut it and welded the flange. Plan on taking just about the entire exhaust off if you want to install it right. I did keep all the A.I.R hookups. I will say it was a royal PITA to install. You will have to make a new bracket for your alternator. I've had mine on for a few months now and them seem to be ok.
Old Apr 27, 2006 | 11:15 PM
AGENT 86's Avatar
AGENT 86
Doooh !! too late I should have measured them. I was going to take a pic of the stock ports and headmans ports head to head, but forgot that too. They are taller ports than the stock opening but are pretty much the same size sideways. I port matched the sides and tops of the exhaust port and left a shelf on the bottom, similar to a "D" port design. I'm sure they will flow just fine and when i look into the ports of the stock manifold, i am reassured.
Old Apr 27, 2006 | 11:37 PM
Corvette Kid
I'd be surprised if the width was any less than 1.5" as are their standard pipes. What gaskets did you use? Some gaskets have the port measurements on the packaging or at least in the catalog. Assuming you checked them to the header ports before installation, could you get this info? I'd be curious to know and I'm sure Nico'd like to have this reassurance.
Old Apr 28, 2006 | 04:21 AM
dand1892's Avatar
dand1892
Default fit
i dont have elite's just plain black ones on my 89 but before i put them on i sat them over my second set of heads from a zz4(same 113) and didnt look like they would interfere. did almost the same as agent but still have a small leak on pass. side need to go back and weld a little spot.
Old Apr 28, 2006 | 07:19 AM
Nico's Avatar
Nico
From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Thanks a lot for the size and the Pics Agent. That will absolutely help.
Old Apr 28, 2006 | 07:24 AM
Nico's Avatar
Nico
Should indeed be fine to know if there is no problem here. Otherwise I can take the 68440 type. There is hardly any rain here, so that may help to last long.
Thanks.
Old Apr 28, 2006 | 03:05 PM
  #33
CFI-EFI's Avatar
CFI-EFI
Thanks.
Nico,
The 68440 headers appear to be the standard quality, non-coated, headers that do NOT accept the hoses for the A.I.R. pump. Rain has little to do with anything, here. I would think you would want the hook up for the A.I.R. pump. The cheap, non-coated headers for the pump hook up is 48441. Those same headers, with the ceramic coating (highly recommended) is part number, 66441. The Elites are still the 68448s. If I were you, I would e-mail Hedman about the port sizes. *I* think the Elite headers are the better buy, with the thicker gauge tubes and thicker flanges, if the ports fit. It makes no sense why the ports on the Elites would be any different than any other header they make for the same application. If you write, tell them what you read here.
RACE ON!!!
Old Apr 28, 2006 | 03:45 PM
  #34
GRX's Avatar
GRX
Nico, I just got my headers from TPiS. They've been making C4 headers longer than anyone else. I also got their Y pipe. The Y pipe is a work of art too. Got both headers and Y pipe ceramic coated. www.tpis.com
Old Apr 28, 2006 | 05:43 PM
  #35
Corvette Kid
Nico,
RACE ON!!!
The Elites are indeed oval port, according their website. But I just can't believe they would measure only 1.2" wide as someone mentioned earlier. If his did, they have a serious QC issue.
Old Apr 28, 2006 | 09:26 PM
  #36
CFI-EFI's Avatar
CFI-EFI
I looked for the header port size and shape in the footnotes and the application listing, but I didn't find anything. Can you give me a clue as to where you saw that?
RACE ON!!!
Old Apr 29, 2006 | 05:09 PM
  #37
Nico's Avatar
Nico
RACE ON!!!
Old Apr 30, 2006 | 12:42 PM
  #38
Corvette Kid
RACE ON!!!
I did indeed run across it on their site one time which is how I found out. It hasn't even been that awfully long ago but I can't find it there now either. But since the Elites have heavier pipes and flanges, it does make sense that that aspect of the configuration could be engineered a bit differently. I wrote all of this stuff down somewhere, that is the differences in each of their C4 part numbers of which their are several, which we know. I'll see if I can find those notes later.
Old Apr 30, 2006 | 06:21 PM
  #39
CFI-EFI's Avatar
CFI-EFI
I can see how the wall thickness of the tubes and the flange thickness could make some minor differences, but since they are all made for the same applications, I find it hard to believe that there is a major difference in the port configurations. Those damn Hedman are so close to one another and don't seem to follow any logical pattern as to coating or type. *I* keep writing down the wrong part numbers. I would encourage Nico to e-mail directly to Hedman about the port size, and any other concerns to get their assurances he will have no problems, down the road. I would tell Hedman that you read about the 1.5" X 1.2" port size on the Corvette Forum, and that without their assurances, you are reluctant to invest international freight, and custom duties on a questionable product. If their customer service department is worth a darn, they ought to have some answers for you.
RACE ON!!!
