From: 1984 crossfire, Alhaurin de la Torre Malaga, Spain
Hedman hedders - hooker headers, size?
I am looking for hedders (headers) for my 1984 CFI. I selected the 1 5/8 hedman Elite hedders, but cant find a connection between the hedders and the CAT. I may be able to use the 2 1/2 - 3 inch hooker Y pipe, but can´t find any info on the distance between the hedder outputs. Is someone out there that e.g. changed Hedman for Hookers and found that the distance between the connections is the same (or worse, different)?
That's too bad because my Hedman Elite's fit great on my 85 383. I've had them for 2 years and didn't pay anywhere near what Hooker's cost and these headers still look brand new.
Good news, but did you mount a cat? and what Y pipe did you use behind thes hedders?
I bought the hedman elites and will be using the stock Y. I will be cutting back the Y and adding a piece of pipe if needed. The ball socket collector flange should be easy to tie into since you don't have to be dead on with alignment. I will tack it together and pull it out to get a good full weld.
I will try and get it done sunday or monday and post pics.
That´s fine, I can measure the stock Y (1984), so it will give me a clue.
Looking forward to the results, good luck with the installation.
Originally Posted by Aaron's 87
My regular hedman's test fit fine, but I haven't run them on the car yet.
I sent my Elites back because the port was 1.5 x 1.2 oval. The 1.2 was way smaller than my exhaust port.
AND THERE YOU PROVED THE VALIDITY OF MY CONCERNS I live in Spain, so I can NOT sent anything back without hughe extra cost and paying the customs DOUBLE.
Therefore I have to find out what fitment is.
CFI, please chime in here. I consider you as the CFI expert. Do we have a fitment problem here for the Elites?
I apreciate your comment.
No cat, no go at the test. Than I have to drive a suzuki.
Nico, Is there not a cut off date for cats in Spain? In the UK, its August 1992. Anything before that can have the cat removed. eg. my 87 has no cats and passes our mot without issue, although there is still a sniffer test of course, but less stringent than post 92 cat cars.
I would have thought that when your 84 was new. cats wern't fitted to many cars then! or are your rules - if they were fitted when new, they have to remain??
Wasn't your vette imported from Britain? If so it could have had the cats legitimately removed here. Do you see where I am going with this.
Dave
Dave
I see Dave, should be a very good point if I did not live in Spain. It seems that the authoroties here don´t like USA cars thet much. To my information all cars before 1992 may go with 1.5 % CO. My Vette absolutely should have less than 0.5%. I did carefully try to discuss this point without upsetting someone (is dangeroeus, they have the last word), but no discussion possible. 0.5 % and thats it. Also the other gasses are strict like a brand new car.
I think you should very first find out what the spanish law exactly says about the car that old. You cannot trust the officials, they probably don't know **** and are just a pain in the ***.
After you know they are wrong, you should file a complaint about that or try a different inspección place. They are probably just jealous because you have such a magnífico car!
You are probably right, but I really don´t want to open a can of worms. They are very simple here, do not agree? no drive. period. When you try to enter the system with all kind of paperwork, you are lost. They are used to have tons of papers at their desk for many years. I hate it to wait for the archeological file system to turn out my answer and no-drive in the meantime. Do what everyone else does and they are happy. If someone has done it at a test staion, they are happy to repeat that. If the boss says 0.5% CO, thats it. Only if you happen to pass a guy that likes the car, he will change the figures at your paper just as a favor to let you pass. Spain is different. So I solved the problem the easy way, PM me if you want to know.
But the enviroment is no issue in this thread, I passed OK. I am looking for the size and fitment of hedman elite hedders and especially the y between the hedders and the CAT.
His original question was about the width, the distance between the tines or legs of the header flanges between Hooker and Hedman headers. Nico has very limited parts, supplies, and talent available to help him with his projects. He can order the Hooker "Y" pipe if the spread of the collectors for Hookers and Hedmans are close. We don't find anyone that makes a prefabbed "Y" pipe for the Hedmans. If this happened to many of us here, we would just drive with open headers to the muffler shop and have them connected. Nico doesn't have the luxury of that option.
Now, since it was mentioned by Aaron's 87, he is concerned that the ports of the headers may not be proper. The only comfort I have to offer on that subject, is that these headers are made for small block Chevy engines and Hedman has been making headers forever. Any company CAN produce a defective product. I don't know how you guard against THAT possibility. For what it's worth, it is perfectly acceptable for the port in the header to be larger than the port in the head.
RACE ON!!!
The fact that the port fitment is not considered a problem is a relief to me. Thanks for that info. Glad that it isn´t smaller wich should be worse.
AGENT 86
Please measure the center - center with between the hedder connections to the Y when the car is up. That may help me to find a Y
