4+3 OD stopped working
Old Apr 23, 2006 | 07:24 PM
dirtnapp's Avatar
dirtnapp
Default 4+3 OD stopped working
I took my car out this afternoon to give it a good run after doing some fine tuning on my Lt1 intake conversion. I went through all the gears and the went to put it on OD and nothing happened. The light on the dash comes on but it doesn't shift. Is there a fuse for it or relay I can check? I also discoveredd that my climate control has no power. Are they related or did two things break at the same time?
Old Apr 23, 2006 | 09:24 PM
dirtnapp's Avatar
dirtnapp
I just did a forum search and came up with only a little info. Theres a relay for the OD but where is it? \ Im getting pretty frustrated with this thing so any advice will help alot
Old Apr 23, 2006 | 09:42 PM
rodj's Avatar
rodj
Relay on firewall by dizzy.
Other things ;
Is the wire still on the O/D connector at the trans?
The manual switch itself may be faulty.
Will the O/d engage automatically by the ECM?
Old Apr 24, 2006 | 08:38 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/OD%20Switch.pdf
http://members.shaw.ca/agent86/Overdrive-manual.pdf
http://members.shaw.ca/dankai/AC%20Electronic.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Apr 24, 2006 | 09:24 AM
dirtnapp's Avatar
dirtnapp
no, it won't go into OD by itself. The button has to be pushed but it has always been that way. Is it supposed to go in by itself?
Old Apr 24, 2006 | 09:27 AM
dirtnapp's Avatar
dirtnapp
I appreciate those diagrams. I will tinker with it tonight and let you know what happens
To 4+3 OD stopped working
