Ok, slightly misleading yes, but I have spent the past 2 months designing and fabricating my own cold air intake design. Totally built with 3.5" mandrel bent aluminum tubing ( polished for appearance ). Runs through the plastic radiator shroud through the side ( had to cut a perfect 3.5 circle with a tile router, K&N cone filter in the front radiator housing, red silicone couplers, LT1 elbow ( ceramic coated ) with a MAT already relocated ( need to hook it up as it is disconnected in the pix ). Throttle response is improved and top end is improved from seat of the pants. I have a big mouth air dam forcing cold air into the compartment ahead and through the radiator with amplifies the effect.
Some will undoubtedly question the design. Well, I did it as much to be different as to the overall effect. You cant have a smooth 3.5 tube above the radiator due to hood clearance and the cold airs on the market still use the "accordian" black rubber tube which causes turbulance. OK, my design may not work any better than the others, but it is different and in my opinion LOOKS 10x better asthetically.
Hope this inspires others to be creative and try fabricating.
-Bill
This actually inspires me! It is definatley a nice piece of work. And the time you put into it payed off. The only thing that concerns me a tad, is that the intake might be picking up warm or hot air from the radiator. My appologies if I am wrong. I do my share of porting and polishing and I would like to put something like this.
Very Nice
