Engine Rebuild/Install
Old May 25, 2006 | 06:19 PM
prattman's Avatar
prattman
Default Engine Rebuild/Install (PICS)
Hello All,
Last year about this time I made a few posts for info/help, and you folks always came through (Thanks).
I am putting the engine in the weekend of 3 June, so here is a pic, I will post one of the heads I ported later.
http://i58.photobucket.com/albums/g2...s/DSCN2025.jpg
This is my 94 auto, daily driver.
Here are the mods:
GM Hotcam
Cloyes double roller timing gear set
1.6 Crane Gold Race roller rockers
EM long tube headers (ceramic coated inside and out)
CSR electric water pump
stock LT1 aluminum heads ported & polished (I did the P/P)
Comp Cams (26915) Beehive valve springs/retainers
Cut-back valves and 3 angle valve job (stock valves)
ATI SFI rated balancer
MSD Superconductor plug wires (red)
Upgraded to 95 timinig cover and vented optispark
EGR deleted
Air Injection deleted
NGK Iridium Sprk Plugs
Cats Eliminated (sorry Bogus)
LT4 Knock Module
pcmforless tune
I will stay with the stock exhaust at least for now.
I painted the block red with ceramic high temp paint,
powder coated the PCM case (red), throttle body (red),
intake manifold (blck), thermostat
housing (red), water pump housing (black),
alternator/ac compressor
bracket (red) etc.
Heads:
http://i58.photobucket.com/albums/g2...ntakeafter.jpg
http://i58.photobucket.com/albums/g2...takebefore.jpg
http://i58.photobucket.com/albums/g2...austbefore.jpg
http://i58.photobucket.com/albums/g2...haustafter.jpg
Old May 25, 2006 | 07:37 PM
aminnich's Avatar
aminnich
Really nice. Try not to burn the tires off now.
Old May 25, 2006 | 08:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice work I can tell you put some time and love into your project. Oh and money
Old May 25, 2006 | 11:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The head work looks great!
Old May 25, 2006 | 11:45 PM
farscape1a's Avatar
farscape1a
DUDE!!! THAT ENGINE IS BEAUTIFUL!!! i hope my 383 looks like that when i'm done! nice job!!!
Old May 26, 2006 | 12:12 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Holy Cr...p That's a beautiful piece of MEAT! I know a really good tire shop for your new rubbers you'll need!! Post what it does in the 1/4 in the future.
Old May 26, 2006 | 07:16 AM
prattman's Avatar
prattman
Thanks for the compliments, I don't have access to a 1/4 mile track locally, we have an 1/8 mile.
A younger fellow I work with and I are going to line them up on the strip after I get it broke in. He has a 02 Trans Am WS6 with the LS1.
I think he dynoed at 318rhp.
I will let you all know what kind of time I run, I hope to get on a dyno also, will post the results.
prattman
More engine pics:
http://i58.photobucket.com/albums/g2...s/DSCN2027.jpg
http://i58.photobucket.com/albums/g2...s/DSCN2026.jpg
Old May 26, 2006 | 08:09 AM
elkabong's Avatar
elkabong
Very nice indeed.....
Old May 26, 2006 | 01:15 PM
TucksC3's Avatar
TucksC3
Looks Awesome!!
Old May 26, 2006 | 01:24 PM
Ttime's Avatar
Ttime
That's just HOT!
Old May 26, 2006 | 04:12 PM
prattman's Avatar
prattman
Can't resist posting a couple of more pics.
http://i58.photobucket.com/albums/g2...akebefore2.jpg
http://i58.photobucket.com/albums/g2...takeafter2.jpg
http://i58.photobucket.com/albums/g2...hotos/bowl.jpg
http://i58.photobucket.com/albums/g2.../bowlafter.jpg
Old May 30, 2006 | 11:33 AM
MarkuzLS1's Avatar
MarkuzLS1
Better hope it runs as good as it looks.
Old May 30, 2006 | 11:38 AM
STL94LT1's Avatar
STL94LT1
Good luck with the engine install.
Keep us updated.
Old Jun 5, 2006 | 08:56 AM
prattman's Avatar
prattman
Update:
It is ALIVE.
We got the old engine out in 3 hours. Took awhile longer getting the new one in due to several things including changing out the valve retainers/locks that were for a LS1. I also had trouble with the engine rotating very hard by hand.
We pulled the pan and a friend of mine found the problem, I nicked one of the connecting rod journals on the crank and it was digging into the bearing.
We corrected the problem, finished the install and she is runnng great.
I will go the the exhaust shop this morning and get it hooked up properly, and flash the tune to the PCM this afternoon.
Many thanks to all that have provided advice and help.
prattman
Old Jun 5, 2006 | 09:34 AM
MarkuzLS1's Avatar
MarkuzLS1
Hey, Hey!! Congrats on the successful install. Sorry I didn't make it out that way to check it out, I got tied up in Huntsville all weekend.
Get it broken in, I'm ready!
To Engine Rebuild/Install
