TPS setting for MAP car?
Old Aug 29, 2001 | 01:35 AM
corvette7591's Avatar
corvette7591
Default Re: TPS setting for MAP car? (tntcorvette)
The Tps sensor should be set to .54 v +-.075v, with the engine off and the key in the on position. Use a mulit meter and stick the probes in the back of the plug. use the top two wires
Old Aug 29, 2001 | 09:09 AM
91-Z07Coupe's Avatar
91-Z07Coupe
Default Re: TPS setting for MAP car? (corvette7591)
The lowest I could get mine to adjust to was 5.8.
Old Aug 29, 2001 | 10:11 AM
-=Jeff=-'s Avatar
-=Jeff=-
What is the factory TPS setting for GM V8 MAP cars?
As the others had said which is basically the same if you had the MAF still
Old Aug 29, 2001 | 10:13 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: TPS setting for MAP car? (91-Z07Coupe)
on MAP cars they're not supposed to be adjustable. The ECM will see whatever the voltage setting is at startup and that will be considered 0% throttle. On my '90, the TPS is not slotted to allow for adjustment.
Old Aug 29, 2001 | 10:57 PM
corvette7591
acording to the corvette service manual you must set the tps sensor to .54v +-.075. and when you turn the switch off and back on the computer will reset itself.
Old Aug 30, 2001 | 07:20 AM
vettenuts's Avatar
vettenuts
Default Re: TPS setting for MAP car? (Marcho Polo)
BINGO!!! If you are talking about a 90 or 91 L-98 Vette, then there is no adjustment for the TPS.
PS: If the ECM senses a lower voltage after startup, it will reset to that lower voltage. This is to correct for partial throttle application during startup.
Old Aug 30, 2001 | 10:45 AM
Marcho Polo
Former Moderator
Default Re: TPS setting for MAP car? (vettenuts)
Hey, learn something new everyday! I knew the '90 and '91 were not adjustable, but didn't realize it would reset if you had partial throttle at startup! I was even wondering about that the other day when I started the car with my foot on the gas by accident.
To TPS setting for MAP car?
