Windshield wiper problem
Old Jul 11, 2006 | 07:03 PM
90convertible for me's Avatar
Cruising
Default Windshield wiper problem
Hi you all. I am new to the forum. I have a 90 convertible with 85000 miles, bought it 3 months ago. A couple of weeks ago I got caught out in a rain storm. I tried to run the wipers but not until I turned them to high did they do anything. Am I looking at a new motor or what? Appreciate anyone's experience with this.
Old Jul 11, 2006 | 09:25 PM
Brimis's Avatar
Brimis
I would guess the motor before the switch.
Old Jul 11, 2006 | 10:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'll say the switch since you proved the motor works.
Old Jul 12, 2006 | 07:52 AM
runner140*'s Avatar
runner140*
Old Jul 12, 2006 | 08:46 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The lower voltage on the switch or settings are not making the connection albeit the high side is working. Start w/ the switch it sounds, as Agent86 said "I'll say the switch since you proved the motor works."
Look here for the motor but they don't have the '90 switch for winshield wiper only 84-89 http://www.madvet.com/shop?frame=3.5434
Here is a switch that might help at Ecklers http://www.ecklers.com/product.asp?p...dept%5Fid=1168
None at ZIP sorry!
You'll have to do a search for the switch or look at other parts stores for it!
Thanks,Matt
Old Jul 12, 2006 | 09:47 AM
Five Window's Avatar
Five Window
Default Parking relay
Had same problem, remove control box from car (upper firewall) and check contacts on relays. Clean them and reassemble. Mine were dirty and misaligned. Works fine now. The parking relay is the most likely one.
Old Jul 12, 2006 | 10:36 AM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Old Jul 12, 2006 | 06:45 PM
Cruising
Thanks for your responses. Is the control box on the front of wiper motor where electrical connections goes in?
Old Jul 12, 2006 | 09:48 PM
RonsRed88's Avatar
RonsRed88
Here's a handy diagnostic chart from my 88 shop service manual.
Old Jul 12, 2006 | 09:58 PM
madmatt9471
After reading another member response it brought to mind that once on my Suburban the winshield wiper motor did the same thing! What I did was take the front cover off of it and remove the circuit board and inspected it closely and found that the soldering spots were cracked around the base of the solder. So I got my soldering gun and heated the solder up and added alittle as well and re-soldered all the suspect spots. Took care of the problem so I did this on my GMC work truck too!for it had the same problem(What happened was the vibration cracked the solder joint on the circuit board of the wiper motor). Re-soldered them and all was well. Hope this helps!
Thanks,Matt
To Windshield wiper problem
