No brake lights
Old Jul 18, 2006 | 11:15 AM
dbaction's Avatar
dbaction
Default No brake lights
Here's one ... 1994 coupe / auto. Problem is no brake lights.
Center brake light works. Flashers work. Turn signals work. Tail lights work. Stop/Haz fuse good. Brake pedal switch removed and tested .. okay.
Could it be a bad turn signal switch?? If so how do I get at it?
Don
Old Jul 18, 2006 | 01:45 PM
pcolt94's Avatar
pcolt94
No books here right now, but I do seem to remember that it is two different circuits. But before I went to far, check the 4 way flasher switch, (on column) and flasher assembly. Can't say much more till I look at the book.
Old Jul 18, 2006 | 07:47 PM
Quiktrp94's Avatar
Quiktrp94
It is the turn signal switch. Happened to mine 2 years ago. You have to pull the steering wheel to get to it. Just follow the manual. You can borrow the tools at Auto Zone or comp. stores. Good luck, Robert
Old Jul 19, 2006 | 11:29 PM
dbaction's Avatar
dbaction
Thanks for the reply. Does the column cover behind the steering wheel have to come off? If so how? Do I need to take the key switch out to remove the cover? Sorry for so many questions ... I don't have a manuel.
Don
Old Jul 24, 2006 | 09:51 PM
dbaction's Avatar
dbaction
Default Turn signal switch
Thanks for the direction. It was a broke wire at the bottom end of the harness for the turn switch. I was looking for current at the connector before removing the switch from the column and fixed it with a spade connector. $0.00 cost parts $???.00 cost aggravation.
To No brake lights
