How do you turn the fuel pump on?
Old Jul 25, 2006 | 02:59 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Default How do you turn the fuel pump on?
There is a way to turn on the fuel pump to prime the fuel rail....right?
(Besides the key on, pump auto-on for 2 seconds, rest for 10 seconds, repeat)
I just swapped cams, I put the motor back together and with no changes to the fuel rail (same regulator and injectors) and hooked the lines up correctly. It won't build fuel pressure at all... ? ? ?
So if there is a way to get the pump motor to stay on...that would be excellent!
Old Jul 25, 2006 | 03:56 AM
Eike's Avatar
Eike
Use the fuel pump test connector - works great.
Just put 12V from a bulb of the interior on it ...
Old Jul 25, 2006 | 07:02 AM
pcolt94's Avatar
pcolt94
If you have the correct wiring diagram and color codes I would just disconnect the pump connector and put external 12 volts to the pump. Make sure you do it correctly and don’t damage the fuel sending unit.
If there is no pressure in 2 seconds which is long enough to pressurize, running the pump longer might not help. You might want to check out the fuel filter and the pick up in the tank for starters. You can also disconnect the hose from the tank unit and see if anything is coming out from tank and then work forward if need be. You can check the return line also.
Are you sure your gauge and measurement connections are good. Did you depress the Schrader valve momentarily to verify there is really no pressure?
Old Jul 25, 2006 | 08:30 AM
redrose's Avatar
redrose
the wiring diagram above does not apply to the 86 vette....on the 86 vette you jump 12v into the "G" pin of the ALDL to run the pump..."G" pin is furthest left on bottom row.
Old Jul 25, 2006 | 08:47 AM
Vetracr's Avatar
Vetracr
I used to have fuel pump connector on my 86 and 90 L-98's. I can't find the connector on my 93 LT-1. Is there one and if so, where is the connector?
Larry
Old Jul 25, 2006 | 09:08 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Jul 25, 2006 | 11:09 AM
RRT vette's Avatar
RRT vette
too
Old Jul 25, 2006 | 11:48 AM
CFI-EFI's Avatar
CFI-EFI
Blow in it's ear.
If that doesn't work, apply 12 volts to terminal "G" of the ALDL.
RACE ON!!!
Old Jul 25, 2006 | 11:51 AM
pcolt94's Avatar
pcolt94
VETRACR - This is on my 94, I think 93 the same.
Remove the gas hatch cover with the 4 screws. Look down and slightly backwards and connector is there. It does have a locking pin that needs to be removed.
There are 3 wires. Black is ground and gray is power for the pump and the purple wire is the float unit. Hope this helps.
Old Jul 25, 2006 | 12:03 PM
USAsOnlyWay
Ahh its the G pin!
I knew there was one of these.
We'll see what happens, thanks guys!
To How do you turn the fuel pump on?
