Stumbling at the starting light !!!
Old Aug 13, 2006 | 02:29 AM
rssshen vette's Avatar
rssshen vette
Default Stumbling at the starting light !!!
I went to the track today. My first trial run was a good run .31 reaction time 60' ... 1.76 and 1/8mile 8.22@ 84mph. Everything seems to be fine. On my second pass, the car stumbled when I launched from the starting light and it continue to do this for the next 3 passes. I was able to let the car engine cool down to 160-170 degrees before making each run. I drove to the track 30 miles and back home 30 mile with no problem. Has anyone had this problem? What should I be looking for to fix the problem. I've already looked at the vacum lines, and adjusted the fuel regulator from 43 to 36psi. I lost on this one
Old Aug 13, 2006 | 08:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Strap a fuel gauge to the windshield and monitor it while you go for some WOT blasts. Maybe your pressure is dropping while in WOT.
Old Aug 13, 2006 | 10:09 AM
bjankuski's Avatar
bjankuski
How full was your fuel tank? If it was less then 3/8 tank the fuel could have sloshed away from the pump causing the stumble.
Old Aug 13, 2006 | 10:28 AM
rssshen vette
I had just a little over 1/8 of a tank
Old Aug 13, 2006 | 01:42 PM
AGENT 86's Avatar
AGENT 86
That was the problem. These cars don't like low fuel when accelerating or cornering. I never let it go below a 1/4 tank
Old Aug 13, 2006 | 05:34 PM
rssshen vette
Thanlks Agent 86... that does explain why it never stumble during my 1st or 2nd pass during time trials. I thought by keeping my fuel down below a 1/4 tank would help improve my times. I'll start out with 3/8 to 1/2 and see how that will do. Thank for the info.
To Stumbling at the starting light !!!
