Intermit Code 13
Old Aug 27, 2006 | 08:47 PM
jzvette's Avatar
jzvette
Default Intermit Code 13
Had a Intermit Code 13 on the way home from Carlisle. About a hour and a half into the ride home on the PA Turnpike the Service engine Light came on and went back out. Of course as soon as I got home I checked for stored codes , code 13, O2 sensor. I was going to clear code and see if it comes back on since it was not a hard code. Any info on if thats OK or should I try and diagnose further?? jzvette
Old Aug 27, 2006 | 10:41 PM
jzvette's Avatar
jzvette
anyone, any info
Old Aug 27, 2006 | 11:14 PM
SunCr's Avatar
SunCr
13 is an open in the Circuit. Check the connector and wiring - often it will hit the header and burn up - hopefully yours is just a loose connection.
Old Aug 28, 2006 | 08:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2013.pdf
Old Aug 28, 2006 | 11:59 PM
jzvette's Avatar
jzvette
SunCR and Ageny 86, thanks for the info. I'm going to check my O2 sensor connection and wire. I forgot to say that I have a cat-less front Y-Pipe(still has center cat) , I'm not sure if that could contribute to a code 13. The code is intermittent for now, and it hasn't affected my engine idle or performance, but it couldn't hurt to check the connection and wire. JZ
To Intermit Code 13
