Yes it is free, and Vader86 is correct. The screen is there to straighten the airflow too the hot wires. This give more accurate g/sec and I will not suggest it as you could damage the hot wires and make yourself have to get a new MAF. Gain is minimal and not noticable.
Everything I have read has indicated no power gain. Besides the screen keeping out debris, it does regulate the air flow so it is uniform across the resistors that control the A/F mixture. Thats why we clean them, so they perform properly.
Some have taken it out and said there is no difference in performance and it runs well. But how do you know the computer calculations are not thrown off and sacrifice of fuel mileage. If there is no difference, then why take it out and alter the design.
Thanks guys. I'm referring to the article in Vette Nov '06 page 68.
"We were stunned when the Dynojet registered improvements of 9 rwhp and 7 rwtq- precisely what Mid America claims for the unit in its catalog."
The 'unit' is the 2 end pieces without a screen for the factory MAF housing. Part # 616-002. Claims 1000 Cfm vs 650. I just wondered if it would screw up the readings.
In a thread on this topic about 6-8 months ago, Alvin from PCMForLess stated that he sees about +5rwhp fairly consistently on stock-ish LT1s in back-to-back dyno tests.
On an F-body with the 90* elbow in the intake tract (ie. high-pressure wall down one side), descreening a MAF can actually hurt power production...because, as stated above, the purpose of the screen is to aid laminar airflow over the sensors. The Vette doesn't have this particular problem.
In any case 9rwhp seems high. What power level was the engine in the Vette mag article putting out?
It does very little. I'd leave it alone. I descreaned mine years ago and never noticed any difference in track times, etc. It went bad a while later and I never modded the new one, and still ran the same times.
