tb bypass hose
Old Sep 12, 2006 | 08:45 AM
xflagz51's Avatar
xflagz51
Originally Posted by wro87
Back in the 60's 70's I drove mg's healy's and z cars all with su's very similar to a TB (early TB?) never a problem with icing (not much heat either). As far as it goes I don't think unless you live past the norther border you should have a problem. It is manly for prehaeting for better emissions. WRO
Thanks for the info, it's a mod I would like to do, but wondered if it would be a mistake. Real world experience is always a bonus, thanks again!
Adam.
Old Sep 12, 2006 | 09:27 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by Da Mail Man
..ya know, i wish i paid more attention as to what was in front of tb!....let me get this straight.....i pull off two hoses from the tb and join then together with a brass connector of sorts....what about the holes/ports left open on the tb after i joined the hoses together?
The coolant comes from the heater line, through the hose and goes into pass side of TB, exits bottom/front of TB through a hose to nipple at front of intake. You can mate the hoses together or better yet toss the 2 hoses and replace with one long piece of 5/8'' hose. I ran my hose under the AC compressor and straight into the intake. You can't see it which is better than seeing it lying over your valve covers.
Here is a couple of pics of the hose route i used. I did bend the hard tube at heater line so the hose would arch nicely under the AC.
Old Sep 12, 2006 | 09:51 AM
Aardwolf's Avatar
Aardwolf
PVC will deform from heat. I had a PVC tee on mine and it bent into a U shape, I decided to remove it incase it got brittle. I just went with a new hose, I bought five feet of heater hose and new clamps. You can then route the hose much nicer. This makes taking the TB off very easy. For new people doing this, look at the clamp before buying it, some really suck! Use a quality clamp.
Old Sep 12, 2006 | 10:22 AM
vader86's Avatar
vader86
Originally Posted by MATCHLIGHT
I see most of you that talked about the bennies of this mod live in the deep south. I live way up in the cold Northeast and the temps are starting to get a little brisk in the morning, will the throttle butterflies ice up in the spring and fall?
Thanks,
Adam.
Your plates wont freeze, its got to get DAMN cold for that to happen, and it needs to be driven under low part-throttle conditions for a few minutes for that to happen. This thing was done during the Canada winter testing that occurs for every GM model.
Such conditions that no C4 owner would risk driving their car in, how often do you drive in sub-zero weather when there isnt snow on the ground?
Old Sep 12, 2006 | 10:32 AM
RRT vette's Avatar
RRT vette
I agree, you would probably have to live in the North Pole for the throttly body to stick from cold weather. The coolant runs through the TB to warm it up during very cold weather. There is no performance gain from this mod, only the mind set that the TB doesn't heat the incoming air as much.
Old Sep 12, 2006 | 11:20 AM
RWDsmoke's Avatar
RWDsmoke
Iceing can occur at 32 to 38 degrees while driving at highway speed. It will melt by the time you stop the car and open the hood to see why your car is not running right. Very unusual but can happen if under the right conditions. I wouldn't worry about it unless it is a daily driver.
Old Sep 12, 2006 | 01:02 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Here's my bypass setup...
Old Sep 12, 2006 | 01:12 PM
RRT vette's Avatar
RRT vette
Ahhh, all I see is chrome.
Old Sep 12, 2006 | 03:33 PM
Red_Vette_93's Avatar
Red_Vette_93
I got a upper rad hose for a 96 vette, & a plastic piece to join the hoses on the other side. Removed a couple of hoses that cleaned up the engine
Old Sep 12, 2006 | 04:28 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Originally Posted by vader86
Or you can do what alot of us do, and replace both hoses with one single hose, any long piece of 5/8" heater hose will do
That's what I ended up doing, especially since my heater core is bypassed too.
$4 fix at any autoparts store
Old Sep 12, 2006 | 05:40 PM
xflagz51's Avatar
xflagz51
I don't know, one forum member from Mass took a picture of his C4 right after a blizzard! To answer your question, no. Thank you!
Adam.
Old Sep 12, 2006 | 08:02 PM
GIJoe's Avatar
GIJoe
Ahh, that makes perfect sense, run the coolant through your nitrous system to cool it down
beautiful install job. I need to get my kit reinstalled and polish up some more parts soon before all the big car shows down here next month.
Old Sep 12, 2006 | 08:05 PM
  #33
williammackean's Avatar
williammackean
St. Jude Donor '07
Originally Posted by mm174
Is it possible to bypass the coolant hose going to the throttle body on an 89'? Are there any benefits? Should I just replace the hose?
Just chiming in that I am new to Vettes and the TB bypass has saved me HOURS of wrench time. That alone is worth the $20 for a new hose.
Did it improve performance? Hard to tell.
Old Sep 12, 2006 | 09:32 PM
  #34
vinnies87's Avatar
vinnies87
okay Joe,,,, that was a good shot.... IDEA: wonder if that will work.LOL
Old Sep 13, 2006 | 08:42 AM
  #35
tlong's Avatar
tlong
On the LT-1s you just run the hose from the radiator T directly to the steel heater line under the passenger fuel rail cover. No coupling, no extra hose.
The air isn't going to be any cooler going through the TB at that velocity but the temps under the hood are lowered a little, and every bit helps I guess. The TB and plenum are cool to the touch afterward vs. red hot.
And it's free!
Old Sep 13, 2006 | 12:17 PM
  #36
GIMMESOME's Avatar
GIMMESOME
Has anyone had any problems with the California smog ***** failing your visual inspection after doing a bypass?"Ah!,pluged off fittings.Hold this man for questioning".
Old Sep 13, 2006 | 12:39 PM
  #37
Steel Breeze's Avatar
Steel Breeze
Here's the way I plugged my throttle body coolant pipes. I can't take the credit for the idea though. It was good Ole AGENT 86 brainstormed this one...
To tb bypass hose
Old Sep 13, 2006 | 01:32 PM
  #38
rick lambert's Avatar
rick lambert
I just gotta ask.....why did the General put them on in the first place?
just wanted to spend a few extra bucks.
Old Sep 13, 2006 | 01:40 PM
  #39
Steel Breeze
I used to run a Holley strip dominator manifold, so there is a big air gap under the runners. My carb would freeze to a block of ice in these Utah winters. I'll bet, now that I bypassed my TB coolant passage, this one will to. However, it is like Vader 86 said, "who drives in sub zero weather in the winter time without snow anyway"? I'll give it a shot, as winter is soon upon us here. I WILL report back, should be a fun an educational experiment for the knowledge of the forum. In all seriousness..
Old Sep 13, 2006 | 05:59 PM
  #40
Da Mail Man's Avatar
Da Mail Man
....well, i did the bypass with the line pretty much like you did as well as the t-stat replacement from a stant to a robertshaw balanced t-stat....broke a damn small black vac line right off of a connector right next to and behind the t-stat housing...i remembered a trick to fix it and dammit if it didn't work!.....i lucked out!....removed the iac and tb and cleaned both and set up iac per manual......
