I used to run a Holley strip dominator manifold, so there is a big air gap under the runners. My carb would freeze to a block of ice in these Utah winters. I'll bet, now that I bypassed my TB coolant passage, this one will to. However, it is like Vader 86 said, "who drives in sub zero weather in the winter time without snow anyway"? I'll give it a shot, as winter is soon upon us here. I WILL report back, should be a fun an educational experiment for the knowledge of the forum. In all seriousness..
and right on!!! During the Missouri winters, my queen stays in the garage
Orlando is like the tropics, but I still want the heat to operate.
I respectfully disagree about loosing the heat. I have looked at the hose plumbing and it just does not look to me that is the case. One hose is off the pump and the other is back to the block. Check it out, tell me why I’m wrong?
Paul: We both may be correct. The original post by MM174 was for a 89 model year...just like my car. In looking at your profile, you have a LT1 engine and the plumbing is very different between these two years. Thanks for the note
As I read more of the posts I see it was referring to 80s vintage. I jumped the gun a little on this, but didn’t realize it when I asked the question. Sorry for the trick question, I understand the big picture now.
Ecklers does made a bypass kit for $20 but I was just thinking that getting rid of the hoses might be a better idea by capping the ends. It also appears on my car that the two hoses are different diameters. So a cheep PVC bypass pipe might not work simply.
When I made my post I was talking about an LT1 and yes you can simply cap all 4 ends that way you eliminate both hoses to the throttlebody. It really helps to clean up the bay a little more. As stated you can buy the bypass kit at pretty much any parts store for about $4. The kit contains the small size as well as the larger size.
