EGR Removal
Old Sep 29, 2006 | 12:17 AM
carriker's Avatar
carriker
Default EGR Removal
Does removing the EGR tubes and putting block off plates in their place increase hp any? Or is it purely an aesthetic thing, or that it just makes working on the engine easier. I want to lose mine, only because I'm bored and need something to do to my car. Seems like it would keep the engine bay a little cooler to. Anyway, what all can be removed? Does removal affect the computer any? Can block off plates be made instead of bought? Thanks.
Old Sep 29, 2006 | 06:30 AM
CMYC4GO's Avatar
CMYC4GO
Your combustion chamber temps will go up significantly without an EGR system.
Old Sep 29, 2006 | 06:42 AM
SK.LT1's Avatar
SK.LT1
Leave the E.G.R. system alone.I don`t believe that it affects h.p.
Old Sep 29, 2006 | 10:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I removed mine to clean up engine bay and to aid in the removal of valve covers. Doing it may cause excessive pinging at high coolant temps. I have a 170 stat and never see temps over 200, even in go nowhere traffic. 3 years and going strong
Old Sep 29, 2006 | 10:17 AM
wro87's Avatar
wro87
You could put a 160stat in and do the TB hose by-pass trick and this will help. wro87
Old Sep 29, 2006 | 11:08 AM
Aardwolf's Avatar
Aardwolf
My car is much happier to work on without the EGR. No problems at all.
Old Sep 29, 2006 | 11:25 AM
vader86's Avatar
vader86
No it doesnt increase HP at all. It does remove a way of carbon deposits getting into the head and intake though, which themselves would hurt performance if left unchecked eventually.
Its purpose is to lower the combustion chamber temps, and it only works when the engine is over 170F and cruising. Ditching it without adjustments to the fuel you run or the chip will cause detonation.
You will need the PCM changed to get rid of the Code 32 as well, or your engine light will always be on when the car is hot.
Old Sep 29, 2006 | 11:28 AM
carriker's Avatar
carriker
Ok, it sounds like more trouble than it's worth. My car was running at a max of 228 degrees yesterday, so I don't want to make it any hotter.
Old Sep 30, 2006 | 05:20 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default Egr
don't you have to get your car smog checked?
Geez where I live, it's a $1500 fine for emissions systems tampering
and the EGR reduces ping by aiding in cylinder filling by adding an inert gas (exhaust) that doesn't burn, increasing the ability to pack more actual air into the cylinder (with the exhaust component) without adding to the combustible mix with already too high compression with cat-pee gas that we are forced to run.
Old Sep 30, 2006 | 06:51 PM
lefoy84's Avatar
lefoy84
Removed mine from my 86 because I couldn't stand that pipe that ran from right exh manifold to the intake. Mickey Mouse.
Old Sep 30, 2006 | 06:52 PM
lefoy84's Avatar
lefoy84
Removed mine from my 86 because I couldn't stand that pipe that ran from right exh manifold to the intake. Mickey Mouse. It can be worked around. You won't see one on a race engine.
Old Sep 30, 2006 | 10:25 PM
Aardwolf's Avatar
Aardwolf
No emissions here, never will be for these older year cars. Inert gas, cam overlap does that.
To EGR Removal
