heater core
Old Nov 5, 2006 | 08:34 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default heater core
Did i read my manual correctly when it said to remove the instrument panel assembly to replace the heater core? That means pretty much taking the whole dash apart right? Hopefully im wrong. If so, does anyone have an easier way of doing it? I drive an 86
Old Jan 30, 2007 | 09:44 AM
BillysCorvette's Avatar
BillysCorvette
1st Gear
Default In Process
I am in the process of changing mine in a 85. WHAT A BEAR! I still have one screw to take out on the top of the box. Very hard to get to.
How did you make out with yours???
Bill
Old Jan 30, 2007 | 10:14 AM
PMARTINEZ92126
Default Heater core
it was a real nasty job replacing my heater core. It was my first time so i learned by posting on this site and alot of trial and error. I believe i got the top left screw out by removing the dash pad. Then i used a small 1/4 inch rach. with a wobbler to remove that hard screw to get out. its a pain but well worth it since we had a cold spell here in sunny san diego. im glad i did it. I did find a burnt wire when i was removing the heater core so i decided to rip the entire dash apart. Be careful in removing the plactic pieces because they break easy. I have to replace alot of the pieces that i took off because of age and handling it too rough. I also replaced all the bulbs on the cluster (which i got for 2bucks and change online) and behind the info panel.
i have some pictures of the dash torn apart so email me and ill send you some pictures if you need them.
Old Jan 30, 2007 | 12:15 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
They dont call the C4 the car built around the heater core for nothing
Old Jan 30, 2007 | 08:13 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
No sh*t! Changing the heater core is the most difficult and time consuming job I've ever done on my '86. I finished this task in, oh 5 hours, with badly scrapped knuckles/forearms, lot's of cursing, 3 loose screws with no homes, and a couple of cracked mounting spots. Seriously, wow.
Old Jan 30, 2007 | 09:20 PM
Chatman's Avatar
Chatman
You're in San Diego. Forget about it. Buy hose to connect the feeder lines, seal off the core, and enjoy life. (You are in a cold snap as the low will be 55 degrees.)
Old Jan 30, 2007 | 09:22 PM
Siveck's Avatar
Siveck
It would be a good time to remove the breadloaf permanently if you've considered installing the flat panel. The breadloaf is one of the biggest obstacles and is a biznitch to remove and probably worse to install. If you remove that, the passenger seat, the dash pad, the lower plastic panel, the lower carpet panel, some air ducting, and the computer, then you should be able to see the heater core housing. And if you have several double jointed elbows on each arm along with bendable bones, then it should be no problem.
Old Jan 31, 2007 | 12:51 AM
VQT88Vette's Avatar
VQT88Vette
5 hrs! It took me 9 days, a week with two weekend, given that I only work for 15 min. and go lay down for 2 hrs every time I craw under the dash
Old Jan 31, 2007 | 03:30 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i havr gone into my dash several times and could proball get it all off i under an hour... then i just have to find the heater core and replace it. im not looking forward to it
Old Feb 5, 2007 | 07:09 PM
todd_vette's Avatar
todd_vette
I remember a really good step x step thread on this from last fall but can not find it now... Any-one have that link?
Also wonering if it is still possible to get a new dash frame? Where would be my best chance? Mine has too many cracks and a couple of missing chunks and out-side edges are all gouged up.
Thank-you All.
Old Feb 10, 2007 | 12:36 AM
Carl914's Avatar
Carl914
I hate to take out the dash, but I have done it a number of times chasing shorts. It is a pain in the buttocks for sure, but its something that gets better each time. You might try to get to it by taking out the glove box first then you can see what you are doing to the fire wall.
This was the first year I had a working heater in my 81 in a very long time. It was kinda nice not freezing to death on the way to work. Also the defroser works again, another important thing. You will hate the job, but sooner or later you will be able to enjoy the warmth again. That will make it worth it.
I bought my new heater core off eBay for I think $49, BTW.
www.mycarframes.com
Old Feb 10, 2007 | 02:20 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
don't know the location here, but there was a couple of great tech posts on HC replacements.... if you haven't searched, try,,, you'll probably find some great info...
Old Feb 10, 2007 | 08:22 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Read my post here http://forums.corvetteforum.com/show...od+heater+core
Old Feb 10, 2007 | 09:07 AM
comp's Avatar
comp
Originally Posted by AGENT 86
Old Feb 10, 2007 | 09:28 AM
todd_vette's Avatar
todd_vette
Great job Agent86, but you seem to have forget 2 very usefull tools for this and the prerequisit helper???
1 gallon high octane aviation fuel, about $3
1 Zippo lighter, about $15
1 great and understanding insurance agent, PRICELESS!
But in all seriousness you forgot the box of bandaides, and the Alleeve.
Old Feb 10, 2007 | 10:18 AM
AGENT 86's Avatar
AGENT 86
Thanks Todd, but that's not my write up, it's a copy and paste of Ron's write up. When I do mine in the next few weeks, my write up may contain flammables.
Old Feb 10, 2007 | 10:48 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I did mine in my 85 in two days, a few hours each day. The very best advice I can give you is to take the passenger seat out so you can lay on the floor, makes life a lot easier.
There is no need to come anywhere near the instrument panel. I did mine completely from underneath the dash. I will admit to taking the top of the dash off to see if I could access the top screws better but it was a waste of time.
Keep the bandaids close by.
Old Feb 10, 2007 | 11:27 AM
Fast Eddiz's Avatar
Fast Eddiz
I’m working up the nerve to tackle the failed heater core in my 92. Can anyone tell me if there is much difference in the procedure for replacing the heater core in the years 85-92 or are all C4’s basically the same? Thanks
Old Feb 10, 2007 | 03:26 PM
todd_vette's Avatar
todd_vette
I honestly can't remember if the 90ups had the same kind of underdash access??? If yours seems to have enough removable panels under there then it is basicly the same duct work and housing...just no ecm in the way and less wires. But that brace may be tighter to get to?
To heater core
