Electic Supercharger
Old Nov 19, 2006 | 08:11 PM
arkangel81's Avatar
arkangel81
Default Electic Supercharger
has anyone else here seen electic superchargers on E-Bay? i've seen some by supernatural performance on there. they look pretty junky, and claim 20% more HP under WOT, by stuffing 500cfm into yor intake. I'm not going to buy it but i was curious about the feasibilty of this. I have a 6 HP shop-vac that turns into a blower, and have always joked about strapping it onto my intake for a supercharger! wow.. they look dumb to put it lightly.
Old Nov 19, 2006 | 08:16 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I picked up 8 tenths with mine at the strip. I actually installed two, before and after the MAF. Lemme dig up the timeslips...
Old Nov 19, 2006 | 08:20 PM
arkangel81's Avatar
arkangel81
if u r serious i will be amazed, very very amazed... maybe i should strap on the shop vac/blower to my intake! j/k um r u really serious by the way?
Old Nov 19, 2006 | 08:35 PM
CentralCoaster
No.
Old Nov 19, 2006 | 09:42 PM
arkangel81's Avatar
arkangel81
thats a relief!111 has anyone tried one of these?
Old Nov 19, 2006 | 09:48 PM
hippy's Avatar
hippy
I know a guy that was running 11's with one of those electric S/C's on a stock LT1.
Old Nov 19, 2006 | 09:52 PM
Mekanic's Avatar
Mekanic
one of my favorite videos of all time....
http://videos.streetfire.net/search/...ad23ca9564.htm
Old Nov 19, 2006 | 10:13 PM
NitrousSam's Avatar
NitrousSam
That is actually pretty interesting. Talk about a dry nitrous system...that certainly would be a way to describe their spray tactics.
However, the results were interesting!
Old Nov 19, 2006 | 11:09 PM
arkangel81's Avatar
arkangel81
that was so awsomely hilarious!!!! think i need to cut a hole in my hood for a nawz spraying leaf blower thanx!
Old Nov 19, 2006 | 11:12 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
no way . if the electric Supercharger flows 500cfm, at some point it will become a restriction because the throttle body flows more than that
Old Nov 19, 2006 | 11:30 PM
CentralCoaster
If that was true, I'd use my throttlebody to clean my driveway. A throttle body doesn't flow anything if you don't put an engine behind it. Your engine will not suck 900cfm through a "900cfm" throttle body anyways.
Stay in school.
Old Nov 19, 2006 | 11:40 PM
JLeatherman's Avatar
JLeatherman
Were those Z06 rims on the truck?
Old Nov 19, 2006 | 11:42 PM
vetteman9368
St. Jude Donor '08
Stay in school.
no **** sherlock, put a vacuum gauge on your intake. If it does not go to zero at WOT you have SOME sort of restriction, maybe YOU should stay in school. PS I build a whole lot of drag race motors, care to talk engine theory? I'm up for a good debate
Old Nov 20, 2006 | 12:20 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Old Nov 20, 2006 | 12:47 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
To evaluate a forced air system look to how much boost it can provide.
A stock L98 TB will flow about 525 cfm as will the MAF, at one atmosphere, but the stock engine will not require that much air.
The trick is to provide the intake air under increased pressure so that the engine can "pull" in more air on each intake stroke.
If your "leaf blower" can do that, then you have a winnah, assuming you can install an alternator large enough to drive it...
Old Nov 20, 2006 | 01:00 AM
CentralCoaster
What does your vacuum gage have to do with anything? The motor also spins clockwise and the sky is blue.
The leaf blower will become a restriction over 5000rpm on a 350ci motor.
Old Nov 20, 2006 | 01:08 AM
Ruff Rider's Avatar
Ruff Rider
Originally Posted by Corvette Kid
To Electic Supercharger
Old Nov 20, 2006 | 01:26 AM
Kinkajou's Avatar
Kinkajou
One of the problems of electric superchargers is that they can move a lot of air, but they can not pressurize the system.
They usually use electric motors that were designed to remove fumes from boat compartments.
I am thinking of installing one to remove the hot air from the engine compartment by feeding cool outside air. Maybe it will not work but it is worth trying.
Old Nov 20, 2006 | 01:30 AM
ALLT4's Avatar
ALLT4
These electric SC threads always intrigue me. The theory behind an electric SC is sound, force air into the motor right? What's wrong with that, granted these things we see on ebay are probably junk but why hasn't this ever been perfected. I mean electric motors can generate massive torque, look at your starter.
Couple a high torque electric motor to a "geared up" blower and why wouldn't that work? Is there a power in and out issue or something?
Look at some of the smaller turbos, hell they're being turned by nothing more than exhaust gas. An electric motor should be able to provide that kind of force right?
If it's a boost vs. rpm matching thing or boost vs. vacuum, hell that shouldn't be that hard to overcome with an AC motor and frequency drive synced to whatever the need be.
Am I totally crazy here?
Old Nov 20, 2006 | 01:46 AM
Mekanic's Avatar
Mekanic
yes
Originally Posted by Ruff Rider
indeed, this one should be good.
