Requesting brake help....again.
Old Nov 27, 2006 | 10:46 PM
lachrimae's Avatar
lachrimae
Default Requesting brake help....again.
I have brake problems that I can't seem to fix. Thanks for listening:
Problem:
Front brakes get (very) hot even on a short ride because the calipers don't disengage fully.
Probably related, the brakes are very creaky when I come to a full stop.
What I've done so far:
New brake lines (stainless steel)
Replaced the front calipers (refurbished)
Replaced the booster (refurbished)
Replaced the master cylinder (refurbished)
Bled the brakes more times than I can count
Please offer some ideas on what I should do about this problem because the front brakes are getting HOT , I mean RED HOT after a typical drive. I can't even touch the wheels because they get very hot too...
I have a feeling that I'm going to have to re-replace one of the components listed above & I'd like to know which one I should start with or how I can trouble-shoot to try to figure out what is going on.
Should I be buying new components instead of refurbished? Upgrade to a non-c4 oem brake system?
Thanks for your help...again
Old Nov 28, 2006 | 04:41 AM
jrp's Avatar
jrp
Me too, but I've had mine apart enough times to brainstorm a guess or two.
How are the caliper brackets? If it is warped a bit, maybe the caliper binds. If there are bad surfaces - worn, corroded, painted - where the pads rest, it could cause some sticking. However, it does seem an unlikely cause for both sides to do this at once, as your post seems to indicate.
Pads installed correctly, with the anti-rattle springs on the bottom?
Old Nov 28, 2006 | 05:39 AM
VenkmanP's Avatar
VenkmanP
Did you replace the pins when you replaced the calipers? Lube them with appropriate grease? Did you replace the pads?
Old Nov 28, 2006 | 06:58 AM
pcolt94's Avatar
pcolt94
The actuator rod from the booster might be out of adjustment. If it is to long it will depress the masters piston and activate the brakes. Unbolt and pull back the master. Check the length of the rod. It should be approximately just below the imaginary surface line of the booster. It needs approximately 1/8 inch of clearance to the master due to heat expansion of the parts.
When adjusting the rod end bolt, the rod had to be held and the nut turned, in to shorten. I clamp the rod with thin vice grips VERY LIGHTLY and adjust nut. Depress the brake pedal half way down to get the rod out in the open so it can be worked on easily.
Jack the front up before you start and check to see if anything is dragging. Then unbolt the master and see if it releases. After adjusting (if necessary) the rod, re-check brakes pedal and wheel rotation. Might take a few tries
Old Nov 28, 2006 | 08:57 AM
lachrimae's Avatar
lachrimae
Good question. They don't appear to be off but I don't have a tool to measure them to a precise degree. I will consider replacing them since they are still original.
Yes
Yes to all, thanks.
pcolt94, I will take a stab at the booster adjustment and try to isolate the sticking problem as you suggest by testing the caliper lockup before and after releasing the MC.
Thanks for all of your posts, I will keep you updated (probably late tonight).
Old Nov 28, 2006 | 10:28 AM
rick lambert's Avatar
rick lambert
with pcolt, actuator rod. Had the same problem after a friend adjusted it, front wheels were to hot to touch.
Old Nov 28, 2006 | 01:06 PM
Daddy J's Avatar
Daddy J
Had same problem with the actuator rod. This is what I'd check first.
Old Nov 28, 2006 | 02:51 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Check the actuator rod.
Old Nov 29, 2006 | 08:53 AM
lachrimae's Avatar
lachrimae
Update: I adjusted the actuator rod (only once so far) and have noticed a big improvement so thanks for your advice!
I recall reading other posts in the past concerning adjusting the rod too far where it may create a dangerous situation (no brakes ). The service manual shows a GM part that helps to nail down the "go" and "no go" adjustment levels for the rod... have any of you used it or do you just adjust to where it is just able to fully release the calipers?
Old Nov 29, 2006 | 01:21 PM
Daddy J's Avatar
Daddy J
Here are a couple of threads which maybe of help to you.
One by pccolt94 http://forums.corvetteforum.com/show...r+actuator+rod
as he has the best description on how to do this that I've run across and is far more eloquent than I am. Note: This is on lengthing rather than shortening the rod but the procedure is the same.
This is another thread I saved with a lot of good info. http://forums.corvetteforum.com/show...r+actuator+rod
I particularly liked the idea of edcmat-l1 of cracking the bleed screw to see it that further retracted the caliper. Also see Hot Rod Roy's "squirt" test.
Sounds as though you are on the right track...Hang in there!
Old Nov 29, 2006 | 02:54 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
When it's properly adjusted, you should feel a very small amount of slop in the brake pedal by hand, before the pushrod hits the m/c piston.
Old Dec 6, 2006 | 04:54 PM
USCG's Avatar
USCG
Had a '91 Ford Taurus with same problem (Teenage son recently sent this car to the graveyard...I pretended to be upset). Only the fronts were affected, and one front wheel got so hot once it melted the plastic hubcap.
None of the Ford dealers could/would fix it, and I noticed that the pedal was not coming back up all the way (probably only about 3/4 back). I was coasting downhill once and reach up under the brake pedal with my toe and pulled the pedal all the way up.....brakes that were dragging now released!
I put a small hardware store spring on the brake pedal to pull the pedal up all the way. Why it did not do it by itself, I don't know. But, we went thru all the usual suspects...change pads, calipers, rotors, fluid, etc etc.
If this was my C4, I would want to fix it correctly, but on that car, it was just one thing after another. So, if you're looking for a simple solution, check if the pedal is coming back all the way.....
Good Luck.
Old Dec 6, 2006 | 06:30 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
To Requesting brake help....again.
