Question on interchange of engine accessories
Old 12-03-2006, 03:30 PM
gene284
gene284's Avatar
Default Question on interchange of engine accessories
Do any of the L98 and LT1 engine accessories interchange.
I'm building up another L98, and wondered if the LT1 power steering and bracket will mount on the L98 block/heads, as well as line up with the crank pulley.
Old 12-03-2006, 04:11 PM
lefoy84
lefoy84's Avatar
Don't think so.
Old 12-04-2006, 12:28 PM
gene284
gene284's Avatar
ttt
Old 12-04-2006, 05:38 PM
93 ragtop
93 ragtop's Avatar
Gene, I think they are totally different. Just for your info, the ps pump is on the bottom on the drivers side (LT1) and the air pump is electric on the LT1 as well. Also, there is no belt drive for the WP on a LT1.
By the way, the vette is different then the F-Body on accesories
Old 12-04-2006, 06:35 PM
gene284
gene284's Avatar
Thanks for both the responses. I think the F-bodies use a long water pump, so you are probably right on that.
I didn't know about the LT1's, I knew about the water pump situation, was trying to use the PS pump if possible (from the LT1) and move the alternator closer to the water pump on the L98. Deleting the air pump also.
Thanks again.
To Question on interchange of engine accessories
Quick Reply: Question on interchange of engine accessories
