Scorpion RR
Old Dec 10, 2006 | 01:47 PM
Pelleplutt's Avatar
Pelleplutt
Default Scorpion RR
Are these available as self aligning ?
Pelle
-90 ZF6 vert
Old Dec 10, 2006 | 03:02 PM
VenkmanP's Avatar
VenkmanP
Yes.
Old Dec 10, 2006 | 04:06 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
On an 89 I used CAT 1.6 narrow, self aligning roller rockers. Required no mods to the valve covers. No problems so far.
Old Dec 11, 2006 | 12:19 AM
rklessdriver's Avatar
rklessdriver
Yes they manafacture a few different self aligning versions. These PN's would be what you need for your Corvette depending on which ratio you wanted.
PN 1035 3/8 stud narrow body 1.5 ratio
PN 1036 3/8 stud narrow body 1.6 ratio
They make a very nice prouduct.
Will
Old Dec 11, 2006 | 04:29 PM
Pelleplutt's Avatar
Pelleplutt
I think i will go with p/n 1036.
Since i am looking into more mods later on, i am also looking at the
comp cams beehive springs.
Do i have to adjust the valve spring on 113 heads by shimming ?
Pelle
-90 vert ZF6
Old Dec 11, 2006 | 04:48 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You may need to grind the drip tabs on your valve covers and use thicker gaskets.
Old Dec 11, 2006 | 05:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Whenever you install valve springs you may need to ge the desired installed height and so seat force.
Old Dec 11, 2006 | 06:27 PM
RacerX70CC's Avatar
RacerX70CC
Will
I keep both in stock as a matter of fact... Another feature of the Scorpions over Cranes is the rocker body is shaped to eliminate valvespring retainer interference (just behind the roller tip). I've sold a bunch with ZERO problems..
Old Dec 12, 2006 | 08:30 PM
dizwiz24's Avatar
dizwiz24
Pelle
-90 ZF6 vert
If you're going to get these, dont screw around with the wimpy 1.5:1 or 1.6:1 rockers, go with the 1.7:1 models while you're at it.
I believe nathon plemons has a webpage developed for the swap. More lift is always better.
ROCK ON!
To Scorpion RR
