1994 LT1 Engine swap with 1996 LT1 Engine
I have a 1994 lt1 blown motor.(Spun Rod and broke # 7 piston into little pieces) I bought a Engine and Trans complete with all assories wiring and comp everything. It was on Ebay as a 1994 but it turns out the guy made a mistake in his add and it it a 1996 lt1 (I checked the s/n and he aggrees the car he was parting out was a 1996)
Now I have notice that the only thing that I see that looks differnt is there is some vacum 2 line running to the distributor from the driver side of the intake ( I found in my 1994 service manual that this is to help reduce moisture build up in the distributor and on the other side of the intake there is different vacum componets that are not on the 1994. Also on the 1994 the coil has 2 pulgs (4wires) that plug into it, on the 1996 there is only one plug that plug into the coil(2 wires). Can I just change out the coil and if I do will it work with the 1996 ignition.
I plan on using the original wiring harness.
Any advice?
Nothing is as easy as it seems!!!
Any advice?
