Nitrous
Old Dec 20, 2006 | 10:38 PM
Irocz2173's Avatar
Irocz2173
Default Nitrous
What do you guys think about a cheater nitrous setup that taps into the bottom of the upper intake plenum? I am thinking two fogger jets one for cylinders 1234 and one for cylinders 5678. If you understand what i am trying to say please tell me why it would work or why you think it may not. I am thinking of just doing a 100 or maybe a 150 shot nothing huge. I just dont like the thought of using one fogger jet up front or even the plate system because i dont think the rear cylinders will get the gas. Has anyone tried anything new like this with there system and has it worked or blown the motor?
Old Dec 20, 2006 | 10:43 PM
Mad-Mic's Avatar
Mad-Mic
why not do a tried and true setup and go with a direct port setup for all 8 cylinders?
Old Dec 20, 2006 | 10:48 PM
Irocz2173's Avatar
Irocz2173
Default $
too expensive but yeah i know that would work just wondering if my way will too
Old Dec 21, 2006 | 09:35 AM
neat's Avatar
neat
It will work, some of the LT1 guys are using a system like you are describing. The most difficult part is plumbing N20 and fuel into the lifter valley.
EDIT: Wow, I should learn to read. I was thinking of something completely different than what you are describing.
I think you will run into distribution problems with only 2 foggers in the plenum (you have an L98 right?) and that an intake tract style system might be a better choice.
Old Dec 21, 2006 | 09:42 AM
rklessdriver's Avatar
rklessdriver
With only 2 foggers in the plenum your going to have major distribution problems IMO.
Theres not much room in the intake in front of the 4 forward intake ports for your mixture to properly distribute itself to those ports. It may work as there is a huge signal at the port when the valve opens but, personally I think everything will go strait to the 4 back ports.
Your are better off running the foggers forward of the throttle body with one on each side (ie on fogger per throttle blade).
I know this makes it harder to hide everything but, the only way to plumb it right (and safely)from the bottom is to use 4 foggers IMO.
Will
Old Dec 21, 2006 | 07:50 PM
Irocz2173's Avatar
Irocz2173
Yeah i was thinking of that setup as well with 4 injectors angled to go straight into the runners. I am just worried that i wont have enough fuel pressue to support 4 injectors but i may be wrong about that. Thanks for all the help and if anyone has already tried this please post a pisture or get in touch with me.
Old Dec 22, 2006 | 11:27 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Nitrous ain't cheatin'!
if by "cheater" you mean "hidden install", you can pretty much do a nearly hidden install by putting the nozzel just in front of the TB and wrapping it in black tape. It looks just like a sensor just like everything else plugged into the engine. Everything else can be hidden easily if you have long enough hoses.
Old Dec 22, 2006 | 07:13 PM
Irocz2173's Avatar
Irocz2173
Yeah i know its not cheating. I want it to be hidden like you said but i dont want to hurt the motor that i just bought with a single fogger in front of the TB. I just want to know if what i am proposing will work or if it is worse than the single fogger in front of the TB.
Old Dec 23, 2006 | 01:16 PM
rklessdriver
Like I said if you move it behind the throttle body I think you are going to have all kinds of distribution problems.
If you want to hide it, move it to the bottom (fogger pointing up vertically) of the air cleaner hose about 3- 4" from the front of the TB and wrap it in tape, then put some plastic wire loom covering on the hoses and route them along the general direction with a nice big wiring harness near by. Take your time making it look ike a wiring harness and a sensor and it will look like it belongs there.
Belive me your not the first person to do this. Its actually pretty easy, lots of places to hide stuff under the hood of a Corvette.
Will
Old Dec 24, 2006 | 08:13 PM
Irocz2173's Avatar
Irocz2173
aright thanks looks like i will be placing one fogger in front of the TB and using that black plastic wrap to hide it. I am now thinking about maybe two in front of the TB maybe one for each blade like u previously mentioned.
Old Dec 25, 2006 | 10:32 AM
FOXX's Avatar
FOXX
Iroc, you migh have better luck if you have a mod move this thread to http://forums.corvetteforum.com/forumdisplay.php?f=87
Just tryin to help. I know some guys (such as myself) look only in some areas of forums and avoid others due to lack of intrest. I happened to stumble onto your thread and my own mod skilz kicked in!
Old Dec 25, 2006 | 03:23 PM
Irocz2173's Avatar
Irocz2173
yeah i actually did post it there first actually and then posted the same thing here. no one responded in the forced induction/ nitrous thread and i got 10 replies here i am still looking for advice or pictures. thanks
Old Dec 25, 2006 | 10:27 PM
NitrousSam's Avatar
NitrousSam
I believe I understand what your goal is but I think your approach is going to cause a very uneven distrubution which may cause portions of your engine to go lean (faster burn rate with nitrous and not enough added fuel for each cylinder). If you already have everything to do this project just buy a used plate and it will be much cheaper in the long run that pulling the heads off to inspect which piston and ring you cooked. Another option would be to use your fogger's dry and cap off the fuel side and spray it in front of the maf (only recommened on smaller nitrous settings). I have played with this and had moderate results but it should be safer than your original plans. Regardless of your approach start small and work your way up to higher nitrous settings. Good luck to you and happy hot rodding.
NitrousSam
Old Dec 26, 2006 | 12:41 AM
AZC4Guy's Avatar
AZC4Guy
why do you want it hidden?
Old Dec 26, 2006 | 10:27 AM
Irocz2173's Avatar
Irocz2173
Ok, like i said i want to use a 150 shot nothing big but what i am doing is using foggers because i can get them for free. Angelo Valla, a Pro-8 racer and my best friend, offered to help me build this motor and put a shot on it. I have done all of his computer controlled timing on his car for the last year and a half and i know a lot about big shots like 400+ but i have never installed or worked on a computer controlled fuel injected street car with a small nitrous setup. To answer your question i want it hidden because i want to be able to open the hood at a car show and say its original. Theres nothing more to it than that. I understand the distribution problems now and also realize that if the computer is going to recognize the added air it will need to go through the MAF right? Nitrous Sam sounds like he knows what he is talking about and i would love to hear back from you again. Thanks for all the help guys.
Old Dec 26, 2006 | 02:19 PM
NitrousSam's Avatar
NitrousSam
Feel free to contact me by PM and I would be happy to help.
Sam
Old Dec 26, 2006 | 02:47 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Sounds like you have a very solid background as well.
Oh, you could do far worse than listening to NitrousSam . . . he's been playing with N20 for many years.
Old Dec 26, 2006 | 10:07 PM
NitrousSam's Avatar
NitrousSam
PM received and replied.
To Nitrous
