Spark plug wires length
Old Jan 16, 2007 | 01:10 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Default Spark plug wires length
Ive been thinking about plug wires lately and I was wondering
Shouldnt all the wires be the same length for consistent firing
It seems like a longer wire would fire fractionally later than a shorter wire
Any engineers out there?
Old Jan 16, 2007 | 02:44 PM
mseven's Avatar
mseven
Originally Posted by 94ZR1
Ive been thinking about plug wires lately and I was wondering Shouldnt all the wires be the same length for consistent firing It seems like a longer wire would fire fractionally later than a shorter wire
If all wires are good I can't imagine there being that much difference in resistance, based on the max. length of approx.2ft.
Old Jan 16, 2007 | 02:59 PM
pcolt94's Avatar
pcolt94
Lets not get length, and resistance mixed up. A resistive wire will cause a lower spark power. The length of the wire is a function of time. The longer the wire, the more time it takes for the spark to get there. So resistance is not a function of time.
I wouldn’t waste my time calculating the difference in time travel in one foot of wire. The number will be so small, it will make no difference. Besides, all the same lengths would look like a mess and you might just have things arking to ground which would be worse than anything.
Old Jan 17, 2007 | 04:32 AM
VenkmanP's Avatar
VenkmanP
A quick Google search tells me that electrical current propagates in a wire at a speed somewhere in the 0.5-1.0 c range.
Figuring out the time differential is left as an exercise for the reader.
Old Jan 17, 2007 | 06:55 AM
pcolt94's Avatar
pcolt94
Had some spare time so;
For those who just want the answer. In a one foot piece of wire the time differential is about 1 nano second or .000000001 seconds. ( Used one foot for a round number)
Light and electricity travel about 186,000 miles per second (3000 meters/sec). You can do the math with simple algebra by setting up the equation.
Or just read about it
http://en.wikipedia.org/wiki/Speed_of_light
Old Jan 17, 2007 | 07:36 AM
BigLee's Avatar
BigLee
as stated above, the ammount of time for the current to travel through one, or even ten extra feet of wire is insignificant.
resistance of a wire goes up in direct proportion to its lenght.
a two foot long wire will have roughly twice the resistance of one thats only one ft. in lenght.
however, this again basically irrelavent, since probably more than 98% of total secondary resistance occurs across the plug gap itself, and the rotor to cap terminal.... so unless the wire is defective, the ammount of resistance it offers compared to the air gaps, is very small...
To Spark plug wires length
