Some questions for C4 windshield installers...
First, they removed the stock seal at the base of the windshield and didn't replace it with anything. The stock seal looks simply like sticky-back weatherstripping you'd get at Home Depot.
1.) Is this part necessary? (I think it's #2 on the first page I attached.)
2.) If so, will installing it require removing the windshield again? (Whatever it does, it was very flattened down the middle as if it had been sandwiched between to parts originally.)
Also they gouged and bent the metal weatherstrip retainers on the A-pillars, (I think it's part #2 on the 2nd page)
3.) Is this to be expected? or due to bad workmanship? (Of course they didn't consult me prior, they just pryed them off THEN came and asked me if it was ok that they were damaged.
Looks like water would just pour in between them and the glass, you can actually see the side edges of the glass.)4.) Are these parts still available? (I'll give Superior Chevy a call in the morning.)
And lastly, I provided them with new weatherstripping from Willcox, and I'm not sure they got it glued in the right spot, because it's bulging up and out at the top over the plastic A-pillar trim, so whatever retainer is supposed to hold it in is missing (part #18 on 1st page), and I can see daylight through the weatherstripping and the targa top won't go back on. I might be able to put the weatherstripping in correctly with some finesse, but...
5.) If I have to, can I remove and reposition and reglue the new weatherstripping without damaging it? or do I need a new piece?
Here's the Parts book pages...
Thanks in advance. I'll deal with these guys tomorrow, but want to make sure I know what I'm talking about.
I have no leaks, looks like factory new, etc. On the other hand it sounds like you got a 'butcher job'. Hope they make it right for you.
I removed it beforehand so they wouldn't damage it up, but they couldn't leave well enough alone and tried installing it.
Roy
Does it just stick to the windshield and just seal against the dashboard? Surely GM put it there for some reason.
Or is it possible that my windshield has been changed before I got the car? The old weatherstrip looked like it was glued on, they were scraping it off for awhile.
I have been considering a new windshield for mine. Who installed yours and what was the cost?
They tried bending the retainers back straight by hand, but they're not on all the way and bowed out. Here's some photos:
From what I've read on here the bottom rubber seal does require removal of the windshield. My dash is out currently and I'm pretty sure I can't remove that seal.
The "weatherstrip" - are you referrring to the A pillar seal? If so, then if you can get it off before the glue has completely set you might be able to remove it without damage, but once the glue is set it's going to rip. I used no glue when I replaced mine a few years ago and have had no problems.
I go through USAA when I need a w/s replaced, because they have their list of installers, and they guarantee the work. Haven't had anything go wrong, but I'd rather deal with USAA than the glass company if something does.
Do any of you have an opinion about Willcox weatherstrip? I had the installer check it out before using it and didn't have any issue with it.
I was about to add that I haven't seen him here in a while, but his profile shows a recent post.
Wow Kevin, that is only ugly hack job
That trim is available. They replaced my trim and weatherstrip when they(Speedy Auto Glass) did my windshield. They did a great job doing mine but informed me after, that my insurance company will not be covering the cost of the trim. They said I owed them another $700 for the trim. I explained to them that I didn't request the trim and they could take it off, but if they F up my weatherstrip in the process, they best have another new one ready. The manager called me back and so no worries, our fault, the trim will stay on. I don't believe the trim was GM but looks just like the original.
If I were you, I would be having that company redo the nightmare and install new trim.
1. The foam is at the base of the winsheild w/s to keep engine noise down.
2. No you can not install the foam after the windshield is in.
3 Those side mouldings are a gigantic pain in the butt. Sometimes the foctory or the last installer glues them in to the point that tey will get destroyed on the way out.
However a good intaller will do their damndest to get them out in one piece, if I can't I'll show the customer sa I'm doing the job.
4. The weatherstripping should be secure with no bumps at all, and no you should not be able to see light through it.
These cars are a major PITA to do and do right. Take the car back and say you're not satified. I'd see if they'd eat or at least split the cost of the side mouldings, you can get them from GM.
I would not worry too much about the foam it is up to you on how factory you want to keep your car.
GET YOUR MONEY BACK AND DON'T LET THEM TOUCH YOU CAR AGAIN!
Go to your chevy dealer and see who they use and make sure the installer has done a few before.
I only use GM weatherstripping on my cars, but the one you have looks okay.
The problem with that it might cost me significantly more to repair their damage than I paid them in the first place, if I have to buy weatherstrip again and those moldings, not to mention paying someone else to reinstall the glass if that is necessary.
I'll give you guys an update after I talk with the manager today. I did pay with Credit Card to get the guys out of there because they were interrupting me continuously in my work meeting, and didn't check it out closely until after work.
87vette, I removed the dashpad beforehand so they couldn't possibly damage it. Yet they picked it up anyways and tried jamming it into the A-pillars from the front w/ windshield out. I looked at it closer this morning at it IS cracked across the bottom. There's a possibilty it was cracked before as I didn't inspect it closely beforehand, but I've had the dash off many times.
On that subject...
6.) What kind of glue works well on styrofoam?
7.) what's the story on scratched window frames and rusting/rotting out? Is this something I can check or is it too late with the windshield in?
8.) Another forum member mentioned a GM seal that goes between the weatherstrip "retainer" and the reveal molding on the A-pillars. (But that the header retainer and reveal are riveted together as one piece.) Is this something I need to purchase? Or are there off the shelf sealers that are typically used? I can't find any mention of it in the parts manual. Is it this rubber/plastic thin strip in the pic below? What does that seal if the windshield is already glued in place?
I had my windshield replaced eighteen months ago and was very pleased with the results.
You and I need to get our cars together and compare the jobs. PM me.
Larry
code5coupe
Seriously though, where do you live? I'm in Mira Mesa, I'd like to stop by and see what its supposed to look like.
