They don't make anything that'll fit a C4, do they? I looked for a set of Tri-Y's a couple of years ago, but nada for this car.
I'm in the process of buying a new pair from Corvette Kid. He said they dont make them anymore. I was just curious as to if anyone had a set they are using.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'll be curious to see if anyone does. In my four years here, I've never seen anyone mention having a set of them.
Originally Posted by Mekanic
I thought the AIR was much different between the two
It is. Hedman doesn't make anything with the correct AIR piping for an LTx engine. The guys using them are no doubt mostly using the non-emission versions. Problem though, the standard Hedmans don't match up well to the LTx's D-ports, blocking the upper and most important part of it. I've heard that the Elites are oval port though and not round port like the cheap Hedmans. If this is the case, they would likely match up okay to the LTx head.
If LT1 exhaust ports measure :
LT4/LT1 both end ports... 1 7/16 x 1 9/16
Middle Port.....................1 9/16 x 2 1/2
and the el-cheapo L98 headers are 1-5/8" how can they block the flow?!?!? I'm thinking about getting the 150.00 painted set of headers for an L98 (headmans) and installing on my stroker LT1.. but dont want anything to be blocked.. so I'm curious as to how this happens?
does anyone have L98 headers on an LT1 already that can chime in?
Has anyone measured the Hedman Elites lately? I've posted many times about the Elites that I got that were 1.4" wide or less with no room to grind them out. My exhaust ports were wider, but my heads have been mildly ported. So, if someone buys them or has them sitting around, let's get some current measurements on the stock ports and the Elite openings.
Today's your lucky day. Since I planned to port and or gasket-match everything, I measured all of my ports from the TB opening to the Hedman Elite header tube inlet sizes...
New and untouched, my Hedman Elites measured 1.22" Wide X 1.55" High at their widest points. I was able to safely "blend" the ports to better match (at least not block) my new Summit 170 "D" head ports, which measured 1.35" x 1.30".
I ended up at 1.40" X 1.60" on the headers, which was enough for my particular application. I could have went slightly larger, but it was un-needed for my setup. I didn't NEED any height added to header ports, but after a mild clean up, that was final measurement.
Sounds about like the Elites I got. 1.22" is too narrow. I'm pretty sure stock heads are bigger than that. It amazes me that Hedman went through the trouble of making rectangular ports, but did not make them the right size. Their cheap headers are a nice 1.5X"round, which will fit over almost anything. I asked their tech support about the small size, and they offered no answer. They did say if I ground on the headers at all, the warranty was voided.
LT1 and L98 headers are interchangable as far as how they fit to the heads. Of course air fittings are excluded. Brackets for alternators/compressor are going to have to be changed on any header except TPIS, i think. And collector connections differ to from straight pipe to flanged, etc.
I have LT1 EM headers on my L98. I did have to replace the starter, but that thing was a monster anyways. The driver side comes very close to the slave cylinder on my 4+3 so I made a "heat shield" for it.
depending on the years, some cars have 2 o2 sensors and some have one. the headers i got had provisions for 2, i plugged the driver's side on mine and rerouted the wiring to the passenger side since it had more clearance. i had to add a power source for the heated connection anyways so it was a big deal.
