Valve spring upgrade - 1.6 RR
Although not indicated as mandatory it has been said it is a good idea to change the valve springs --
What would be a good upgrade so if I put a cam in I would not have to change them again??
Also- is there a special tool required to remove the retainer on the spring??
http://www.superchevyperformance.com...p/12495494.htm
Other springs might be five times the cost or more.
http://www.competitionproducts.com/p...s.asp?dept=419
Either of these will go to .650 lift.
http://www.competitionproducts.com/products.asp?dept=56
Also PEP, SI and Pioneer make similar 1.250 springs, what you should buy depends on your future cam plans.
Yes, you need a special valve spring compressor and a small magnet (for the keepers) to change out the valve springs on the car.
Will
Decide on what cam you will likely/probably go with and chose the spring to match. Also you may want to decide on which RR ratio to get to match up with the cam.
Also do a nice set of RRs, say the ProMagnums.
