x or true dual
If you stick your head up your *** (or already have it there), Your head and your large intestine will be in the same chamber. The hot air from both will mix.
And if you still don't believe me, eat some refried beans, and tell me if your hair smells like your sphincter.
Thanks for the clarification.
Yes, the two horizontal lines are welded together. It's cut in half and is not a cross section view.
CC, could you please field this question?
Look at the image above. Now imagine a long piano hinge welded inside the 2 pieces that are almost touching. Fold the bottom piece of the resonator up to close up the resonator like it was before it was cut.
The inlet tubes are to the left, the exit tubes that are sticking out are at the right. So a reciprocating saw went right down the middle of the car(as the exhaust is mounted in the car that is). Right between the left and right banks. So if you fold it in half, like the hinge analogy you can picture the center section of the resonator as 1 large chamber open to all 4 pipes, 2 in and 2 out.
I'm a reasonably guy, but this is just plain ridiculous, I think if you read the whole thread you might see why I said what I did.
I have read the whole thread and have seen all of the pictures. Having the two horizontal lines welded together answers my question. Thanks.
[/QUOTE]
There is a big difference in the sound from the two cars. The convertible (No H-pipe) has a sound more like the Sting Rays with the side pipes, louder, more gutsy. The system on the coupe..with H pipe..is much more mellow, and not nearly as loud, which disappointed me, as I did want it louder, like the convertible's exhaust. So in this case....it does seem that an "H" pipe does make the exhaust quieter. The system on the coupe does have a nice sound...no raspy or sputtering, and a nice deep mellow sound...kind of a "gentleman's exhaust"
Also it has one of the reasons I wanted to get rid of the Flowmasters.....NO resonance I will live with the "H" pipe system for awhile, and maybe somewhere down the road, I might experiment with blocking off the "H" pipe, to see if it changes the sound.
just make sure you run a crayon from the engine back, where the crayon STOPS melting is where you put the X-PIPE!!
, just like everything else they adverstise for performance??
with
