Code 36
Old May 17, 2007 | 09:21 PM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Code 36
My 89 Vette started getting code 36's today. My MAF sensor is fairly new, and I replaced the burn off relays last summer. What am I missing? I tried resetting the ECM, by pulling the ECM's fuse. I still get the same code.
Old May 17, 2007 | 10:57 PM
vader86's Avatar
vader86
http://members.shaw.ca/corvette86/Code%2036.pdf
Old May 17, 2007 | 11:13 PM
Sirwilliam1229
Thank you for the quick reply, but the information is beyond my single brain cell.
Old May 18, 2007 | 01:43 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default maf
the maf code will go away if you disconnect the battery.
Then reconnect the battery and determine it is actually gone.
then start the car, wait for the check engine light to come on, and then shut it off, and recheck codes.
If it comes back, you need to check the maf connector, associated wires, and grounds.
Old May 18, 2007 | 02:48 PM
Sirwilliam1229
Thanks for the quick reply! One more question. I took the MAF off, and noticed that it looked dirty inside. Most likely from the oil from the K n Air Filter. Can I use carn cleaner to clean it? Or, shoud I just leave it alone?
Old May 18, 2007 | 02:54 PM
TOMS93's Avatar
TOMS93
I don't know about carb cleaner. But I know that its fragile I probably used the wrong cleaners on the cars that had MAF sensors. I remember using denatured alcohol with success. Hopefully someone will recommend a known good solution.
Old May 18, 2007 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I'm sure I read that there is a MAF cleaner available in an aerosol can.
Old May 22, 2007 | 04:46 PM
Sirwilliam1229
Old May 22, 2007 | 10:57 PM
RRT vette's Avatar
RRT vette
I would absolutely read and print out the link that vader86 posted. You can purchase a can of CFC electrical cleaner at autozone to clean the MAF with.
Old Jun 5, 2007 | 04:53 AM
Sirwilliam1229
Thanks!
Old Jun 5, 2007 | 08:53 AM
Wheelman's Avatar
Wheelman
I have been fighting this recently. Follow the flow chart and if you get all the way to "bad ecm or wiring" like I did, then get a can of contact cleaner and a small screwdriver and scrape on all the contacts of the MAF relays and MAF connector, and bend the pins slightly so they make better contact. This seems to have gotten rid of my problem.
Old Jun 5, 2007 | 10:37 AM
Sam Lam's Avatar
Sam Lam
The C4 cars are aging like the drivers The female part of a terminal connection relaxes over time and you tend to lose electrical connection. This is especially true when you deal in low voltages as is seen in auto sensors. I have been using a product called Oxi-Guard on sensor connections in recent years. This is available at Home Depot/Lowes and seems to maintain electrical contact when you have clean connections. It is found in the "electrical" section of the store. Just a comment for fellow forum members
To Code 36
