Optispark issues - Time to fix it!
The point is the opti works great because has direct drive so no gear slop. And it sends back crankshaft positioning every degree per revolution or 360 data bits per revolution. This coupled to the ECM/PCM which basically is a computer, which can take this data along with the other engine sensor inputs and make highly accurate computations for timing. Loading, RPM, temperature, throttle position, knock and such are just some input factors that the computer can take to deliver the optimum timing made possible by the optispark high precision of output data.
For more detail: http://www.gmhightechperformance.com...htp_optispark/
Now for the failure rate. Mine failed (stumble on acceleration) with 12 years of service on it. Of course in these years you are going to see failures, but that’s with lots of time and mileage on it. The failure rate was lower when the car was new during the first few years and performance was the same. Or to say another way, the failure rate is higher now because they are 12-13 years old, but the operation is superior to most other distributor systems.
Twelve years of operation and no maintenance performed, not bad. Show me other distributors with no service in that time frame. Putting things into perspective, I would like to see how the MSD system (or others) holds up in the year 2019 (12 years).
A sales manager once told me there is no such thing as a lemon car, only lemon owners. Optis are maligned by lemon owners who would not recognize and appreciate slick engineering if it came down Main Street wearing a red hat. Corvette engineers have a tough job. They have to figure out how to bring you advanced technology in a slick package at an affordable price. I suppose the detractors might have a point in blaming GM for building a Corvette to sell in a relatively low price class for that type of car. They should have done all the things the detractors complain about and gone ahead and charged $100K for it to protect their good name. This is what Porsche does, ever try to see what $50K buys you over at their place? It will have four cylinders and be used.
Now if there was a crank trigger setup that was plug and play for my car (ie the CCM recieved the signals it needs from the opti I'd be in. Even if it cost 1 or 2K since a crank trigger would be an improvement. However, a rear distributor is not an improvement and some of the highly anticipated/lauded aftermarket options have not been performing up to snuff in their limited existance.
.......and the symptoms, do not scream OPTI.
I wash my engine with a hose and never have OPTI problem. Just don't hit it with a high pressure stream (same a conventional diff)
The electric water pump is a PROVEN performance increase.... the pump runs one speed its designed to be efficient at that speed. I agree that the factory pump will spin faster at high rpm however, that does not mean it will move more water than the electric pump at high rpms. Since the factory pump has a wide rpm range it may cavitate at high rpm and just waste HP without moving water.
...and the EWP really shines when you're sitting in traffic on a 100* day in a modified LTX with head/cam/headers and a big honking stall TC (known to make some heat) and you're sitting in the cabin at about 68 degrees because the AC is kicking and engine is not overheating.
My second choice is MSD. I keep reading about how good the Dynaspark is supposed to be but hopefully, the MSD is good too. Sure is expensive....
I plan to change to an electric water pump too. I believe it is superior to the stock one and eliminates any possibility of leaks on the opti, although the new opti is sealed with venting.
Billy
just shut off dead at highway speed leaving me coasting to a stop, never to start again. I was told that a seal had gone leading to the
failure. GM charged over $1200.00 for the opti and the job was about
$2000.00 total. That was a couple of years ago when I was totally
ignorant of them available at the prices you guys are talking about and
of course being in Canada adds to the price.
This morning, my garage was a cool 65 degrees so I decided to try to start the car again before the days heat arrived. The car started up smoothly and ran like a charm. Seems like if the optispark was bad, wouldn't it run rough all the time instead of only when it's hot?
I hate to buy a $500+ optispark if the car doesn't need it. It has 65K miles.
Can someone tell me if this sounds like the optispark? Yes, the codes say it's the opti but I've read that other things can throw these codes.
Billy
Factory engineers do not design and approve water pumps that cavitate. Stock pump will not cavitate at any engine speed you are able to produce with your LT-1. The only thing that prevents boiling water and creating steam pockets in the heads in a running engine is pressure. Engine driven pump will produce about 25psi pressure at high RPM which is in addition to closed cooling system pressure. This is the pressure in the heads which is what you need. No electric pump can do this. Electric pumps are probably OK for mild street use or for cooling a drag engine between rounds. If you have a street hotrod then OK, if you have a nice original car avoid them.
I was filled with oil due to a bad timing cover seal, I bought the 95-96 MSD unit (My car is 93, but I have 95-96 cam and timing cover), and I was very impressed by the build quality.
As far as symtoms, my car was doing all sorts of weird things. It would start to miss, wouldn't start, threw all sorts of codes. Trust me, buy the MSD unit and your headaches will be relieved. I just drove up to Chicago for The Bloomington Gold Show without a glitch.
On top of that, I changed the fuel filter, plugs, plug wires, coil, ICM, and the O2 sensors. Save yourself some money and buy the Opti.
Billy
Wilsonbh, I'll be interested to see if replacing the opti fixes your probelm.
Billy
I've studied how to change this thing and it looks like a days worth of work for me to do but it's not rocket science. I'm going to take the plunge and change it out. Will go with a MSD but would prefer the Dynaspark. However, the Dynaspark people have been putting me off for 2 months now with "We're going to get inventory soon..." comment. I have lost faith in them. I'll post my results here. Should be in the next week or so.
The gunshot you will hear is if this doesn't fix my problem...
Billy
Whether or not it will fix this issue remains to be seen, and i guess time will tell.
Water pump removal is pretty simple, remove both your knock sensors to drain the coolant from the block first though, or it will **** out of the bottom of the pump when you go to remove it. That should see you about an hour into the job by the time youve got the pump off, as long as you have the tools for the job.
If they are this difficult to believe before the sale, how could you trust them to be of any help if you had service issues? No thanks, I don't care how good they are.
Although changing the ICM is simple and quick, looking at the engine will not make it run. You need to start somewhere and change something. If you replace the opti, at least you will know you have a new one in there and wont have to mess with it for a good while. If the car runs, then great, if it doesn’t, then you have at least eliminated one major item. If you change the opti, change the wires also because its easiest then. Also get new seals for the water pump and opti shafts (its your only simple shot to change them).
Changing the opti is not rocket science and will take you some time. The biggest problem probably is getting the balancer off. Some come off easy, some don’t. (Mine did not come off till the second day, it was almost like it was welded on). After removal, get the rust off and lube, will not ever be a problem again. *Balancer needs to be installed back in the same position on the hub (hub stay on) as it was taken off. I marked with red paint from the rear before removal. Paint bolt hole tab and edge of balancer.
Aligning the opti on the notched shaft is quite easy but where most mistakes are made. Rotate engine to get notch at top for easy viewing. Align opti correctly, and slide on gently, should almost fall on the timing cover and be flush. Only then put the bolts in. Start engine to make sure it runs before installing water pump. A minute is all you need to make sure opti shaft is aligned and all is good.
There’s more info and questions, best of luck.
