Timing Chain Slack?
Old Jul 7, 2007 | 06:58 PM
92corvette's Avatar
92corvette
Default Timing Chain Slack?
Im in the middle of a cam change on the 92 LT1 and have a new GM timing chain.
I expected the chain to be somewhat stiff and have vitually no slack when installed.
Instead I find that when installed, it has some slack, almost as much as the old chain I took off.
How tight should a new timing chain be when first installed.
Experienced answers and no opinions please. Thanks.
Dan
Old Jul 7, 2007 | 07:14 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Every new SBC timing chain I have installed, has been a tight fit(about 8 of them). Your using new sprockets, right ??
Old Jul 7, 2007 | 07:19 PM
92corvette's Avatar
92corvette
Me too, that's why I asked about it now.
Have you ever done an LT1?
Old Jul 7, 2007 | 07:23 PM
AGENT 86's Avatar
AGENT 86
No. Are the sprockets new ??
Old Jul 7, 2007 | 08:05 PM
92corvette's Avatar
92corvette
Anyone with LT1 experience on this?
Old Jul 7, 2007 | 08:09 PM
clf93lt1's Avatar
clf93lt1
did you put new gears on ? if not that where your slack is coming from.
Old Jul 7, 2007 | 08:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ive seen s bunvh of posts about the GM chains having a little slack. Cant see how it would create a big problem. Get a super tight one and run it for a bit. Bet if you pull the cover you have some slack, they do stretch like anything else.
Has the motor ever been line bored?
Old Jul 7, 2007 | 09:15 PM
Carpenter's Avatar
Carpenter
My LT1 Cloyes double roller set was 'loose'. (and no line bore)
Doesn't factory offer double roller? LT4? Double roller chains are looser than OEM, IMHO.
Why won't you answer '86 and '93? DO you have new sprockets?
Old Jul 8, 2007 | 04:06 AM
BAM92's Avatar
BAM92
I put the Lunatti sprockets, gears, chain on mine brand new from Summitt. It had a bit of slack in it. No problems.
Old Jul 8, 2007 | 01:47 PM
STL94LT1's Avatar
STL94LT1
Hmmmm, my Cloyes double roller was so tight I could hardly squeeze it on.
Old Jul 8, 2007 | 02:30 PM
Carpenter's Avatar
Carpenter
By loose, I mean after install. The chain ("leeward" side) had 'play'. Not tight at all. Installing it was tight though. The only tight chains I've ever seen have been stock non-roller ones. And only most of them, not all.
I've never ever replaced just a chain. I ALWAYS replace both gears.
Old Jul 8, 2007 | 02:38 PM
STL94LT1's Avatar
STL94LT1
Carpenter, even after the install my Cloyes chain was very tight.
Old Jul 8, 2007 | 02:41 PM
Greg Gore's Avatar
Greg Gore
I pulled mine down to replace front cover seals and while I was in there elected to do the chain and gears too because the chain was pretty loose. I was surprised to discover the new one was also a lttle loose but I let it go and buttoned it back up. About all you could do is take two gears and a pile of new chains and go through them to find the tightest one which is not very practical. This is what occurs when you stack up production tolerances: cam bore center to c/shaft center and chain to chain. Wouldn't be worth worrying about on a stocker because a tight chain would loosen up after a few miles anyway.
JAKE's Avatar
JAKE
I just installed a new Cloyes timing chain set on the 388 LT1 I just built. Chain was tight with no slack.
If the gears aren't correctly indexed with each other the chain can still go on, but there will be slack on one side or the other.
Jake
Old Jul 8, 2007 | 02:49 PM
shop14's Avatar
shop14
ive done a few lt1s,double rollor tend to have a bit more slack but nothing extreme either way.You need to install new gears along with the chain to mimimize the extensive slack your complaining about.
Old Jul 8, 2007 | 07:59 PM
92corvette's Avatar
92corvette
My Haynes manual says replace if total freeplay mid way between the sprockets exceeds one inch.
I don't have near that much.
Old Jul 9, 2007 | 07:41 AM
JAKE's Avatar
JAKE
After I've indexed the chain with the cam gear and the crank gear and the camshaft dowel pin, I push UP on the cam gear very hard. This may cause the camshaft to rotate counter-clockwise just a tad.
This has helped me take out any small amount of slack that may exist. Just have to be sure that the alignment dots haven't moved. A straight edge is the way I make sure of that. I use 6 o'clock on the cam gear and 12 o'clock on the crank gear so the dots are as close together as possible - minimizes error that way.
Just remember that with the dots in that position, you won't be on the TDC compression stroke for #1. That's important to remember when installing the opti.
Jake
To Timing Chain Slack?
Old Jul 9, 2007 | 08:11 AM
96lt4c4's Avatar
96lt4c4
I just put in a new Cloyes chain, LT4, it was tight. I almost thought it was too tight, but found out that is the way it should be.
Oh, and my block has been line bored.
Old Jul 9, 2007 | 08:25 AM
anesthes's Avatar
anesthes
How many degrees off do you think an inch of slack is? Hrmm..
-- Joe
Old Jul 9, 2007 | 09:47 AM
JAKE's Avatar
JAKE
Yep, mine was really tight too. My block was align honed not bored though.
If the chain isn't tight it'll cause flucuation in both the valve and ignition timing.
Give me an update on the build when you have a chance.
Jake
