Ferrari type shift gate?
Old Jul 15, 2007 | 11:16 AM
CSS996's Avatar
CSS996
Default Ferrari type shift gate?
I'm not trying to make my car something it is not, but I always dug the minimalist look of the Ferrari shift gate. Has anyone made anything like this? Do you think it could work on an M6 Vette if I (or preferably somenoe else) fabricated one?
Old Jul 15, 2007 | 11:34 AM
Powerdrive's Avatar
Powerdrive
Gated shifters suck monkeyazz, my friend.
Metal obstructions in the shift pattern
Looks cool but that is all.
I would think you could make one to work for a vette though
Old Jul 15, 2007 | 11:45 AM
cv67's Avatar
cv67
St. Jude Donor '05
You could probably take some measurements, cut out a cardboard template and duplicate it in aluminum or sheetmetal.
Old Jul 15, 2007 | 11:49 AM
CSS996's Avatar
CSS996
Well if they suck, why would I want one?
I believe function comes before form. If it is not a good way to go about my business, the boot is fine with me!
Thanks!
Old Jul 15, 2007 | 12:44 PM
rklessdriver's Avatar
rklessdriver
I have to agree that they really suck. My dads Pantera has one. Looks stylish but thats about it. You can't shift it in a hurry to save your life, makes an otherwise fun car to drive not so fun.
Will
Old Jul 15, 2007 | 01:45 PM
bogus's Avatar
bogus
that is the common problem with shift gates... they look neat but are not as functional as advertised.
As an aside, the gates made up for what were essentially crappy shifters... so the gates applied the quality, so to speak, of the shift.
The latest Ferrari's and such that use gates, are using them as cosmetic tricks, the actual quality of the shift comes from the linkage and shifter box. So the gate isn't doing anything.
with that said, if you can build up a decorative gate, I think you may have something.
Old Jul 15, 2007 | 04:01 PM
Terrible Juan's Avatar
Terrible Juan
I've always loved those shift gates. I am diappointed to hear they don't work well, lol.
Old Jul 15, 2007 | 07:20 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Actually, it's funny you should ask this because it is exactly what I'm working on at the moment. I am of the opinion that the stock trim around the shifter area is the ugliest part of the interior, and a prime example of GM's liberal use of awful plastic parts. If you've ever actually removed that part you'll know what I mean about what cheap crap it is. I think this is definitely something that can and should be remedied in a Corvette regardless of if it cannot be done in a way that functionally helps shifting.
Sort of in line with Bogus's idea, the shift gate I am building will be entirely decorative. Since it can't be functional the goal is to make sure it doesn't impair the existing functionality, so unlike the Ferrari shifter pictured above, I imagine that when mine is done there will be a lot of open space in the "gates." This is because I am making darn sure it stays well away from where my shifter has to move. Moreover, I've checked and found out that a flat shifter gate will not interfere with the protective rubber boot that exists below and inside the outer leather boot; the rubber boot is low enough that it will still fit and be able to move just fine under a flat piece.
To make this, I was planning on doing what an above poster also suggested: making a template out of cardboard and then cutting up some solid-colored sheet metal according to that template, and then bolting it to where the stock boot bolts in (it's great that the bolts are underneath and out of view; the metallic surface can then take up the entirety of the visible recessed area). I'm looking for a metal that has a surface similar to the one pictured up there: solid colored, and shiny but not too aggressive.
This is part of a general overhaul of my shifter area; I'm also overlaying the plastic trim with leather or some other material, using rivets and stitching, and I'm adding a decorative spec plate and getting a new shifter ball. When it's done it should look much better than the awful quality of the stock trim piece. I will definitely post a thread with pictures when I put it in the car.
Old Jul 15, 2007 | 07:32 PM
CSS996's Avatar
CSS996
Keep us posted on this one, eh?
Pix are good!
Not sure if big wide gaps are going to look good, but if you are going to invest your time in it, and it looks good and functions properly, you may have a few customers!:o
Wouldn't the bias spring in the stock tranny keep things pretty much moving in the right direction anyway?
I wonder how an after market shifter would affect the length of the gates?
Old Jul 15, 2007 | 09:55 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
"It sucks." Says the people who have never driven a Ferrari.
Old Jul 16, 2007 | 01:11 AM
bogus's Avatar
bogus
and you know I haven't?
A 348. About 5 years ago. I hated the clutch.
Old Jul 16, 2007 | 10:31 AM
Powerdrive's Avatar
Powerdrive
Yeah, Ferrari has 'em they must be good...
Go put one on your car see how you like it.
You might not notice a diffrence if you drive like a granny..... Speed up those shifts and you will see just how much they suck
Old Jul 16, 2007 | 12:49 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
The one's on Ferraris work. It's not a decoration. I worked for a while as a Ferrari mechanic. You either love them or hate them.
To get it to work on the ZF6 you have to go into the transmission.
Unless you just wanted the cover.
Old Jul 16, 2007 | 03:07 PM
MikeyT84's Avatar
MikeyT84
I have driven my uncles 550 Maranello a few times and it reminds me of my Richmond 6...very postive and notchy. Shifting fast in the Ferrari was kinda hard with the gate being as it is. Just my $.02
Old Jul 16, 2007 | 03:11 PM
5abivt's Avatar
5abivt
go down the 1/4 mile with one of those and everyone will think you're learning to drive stick. Beside from them not actually being functional i think they're sexy as hell.
Old Jul 16, 2007 | 05:21 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Off the top of my head, I don't think the gates on the ZF6 gearbox are far enough apart to allow individual slots on a plate like that.
Just as well.
Larry
code5coupe
__________
Often wrong, never in doubt....
Old Jul 16, 2007 | 05:44 PM
LouisvilleLT4
No, they aren't very far apart, and it will have to be quite a bit different than the one in the picture. If I remember right there is some distance to work with between gates at that height, but not much. If I use enough open space in the horizontal section and allow the slots to overlap one another, I think I can pull of the gated "look" without the shifter actually being confined to moving within a slot.
To Ferrari type shift gate?
Old Jul 16, 2007 | 06:53 PM
5abivt's Avatar
5abivt
Remember that without the rubber boot and leather boot there will be considerably more 'noise' coming from the tranny area. I personally love the whine of the zf but driving without the boot is just not for me.. way too loud.
Old Jul 16, 2007 | 07:25 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
It looks cool, for some strange reason nobody has ever let me drive one of them fancy 2 seat Itallian Mustangs
Old Jul 16, 2007 | 08:50 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The ZF has a little more room between gates than any other 6-speed I've driven. It'd depend on the height of the trim piece, and the thicknes of the shifter. Stock I don't see it happening.
