Well I do have a AF gauge and it does read diffrent with the discreened MAF! Before it use to read right above the stoichemetric point and know it reads about half ways throw the rich point!
There are two reasons to de-screen a MAF - increased airflow (although you would need a pretty big motor to need this extra flow) and to lean out the AF mixture. According to TPIS' Insider hints book, the very small HP gain came from leaning out GM's conservative programmed A/F ratio during WOT operation. GM kept things to the rich side to reduce the chance of someone grenading their motor. During closed loop operation, the O2 sensor makes sure to keep the A/F at Stoich. (14.7 A/F if memory serves me correctly)
I'd like to hear an explanation on how descreening a MAF will cause the car to run leaner.
The descreened MAF will have slightly different flow characteristics than a fully screened MAF. The program in the chip is written assuming the airflow characteristics are that of a stock MAF. By taking the screens (and in my case the heat sinks) more air will flow through the MAF. Remember the MAF works by determining how many volts it takes to maintain a certain temp. of the hair size filaments. The filaments are contained within the smaller cylindrical tube inside the MAF. This is why some people who tune TPI MAF cars feel that the MAF scalars in the program need to be recalibrated whenever you modify the MAF.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ok, more air flows through the MAF, so the maf power increases, just as it would running on a cold day. And the ecm compensates by putting in more fuel.
I wonder why I am spending less and less time on the forum....
No, I do know.........more and more threads seem to end up with this kinda crap in it
Maybe we should tell the newbies to use the search engine for "kiss my ***" instead of starting worthless threads on topics that have already been covered...
It is nice that all threads don't end up just dry bare bone facts, nice to see a little color included........but I am really getting bored with these kinda posts..
Oh and CC I am not singleing you out, this practice has just become way too wide spread IMHO.....and amazingly well accepted by the majority of forum members
This why we have a "Report Post" button.
Originally Posted by CentralCoaster
Ok, I guess I need to explain myself then.
A senior forum member created a second username, Warp8, for the sole purpose of trolling threads and stirring up crap. Apparently he's afraid to say what he thinks using his normal username, so he's hiding behind another name. This is why I didn't give his response the time of day.
