88 corvette poor exceleration
Old Jul 30, 2007 | 05:28 AM
deerkill10's Avatar
deerkill10
Default 88 corvette poor exceleration
I have a 1988 vette that starts hard usually on the third primimg of the fuel pump stumbles than finally gets up to 1000 rpm, it also has midrange excelleration troble like it is running on 7 cylinders
new plugs wires plugs
distributor cap and rotor
convertor removed
comp test 121-125 on all 8
new temp sensor
is it time to look at fuel dilivery system
123k on stock vette
Old Jul 30, 2007 | 05:42 AM
86PACER's Avatar
86PACER
Any codes?
Old Jul 30, 2007 | 06:21 AM
deerkill10's Avatar
deerkill10
no codes
Old Jul 30, 2007 | 08:17 AM
88espo's Avatar
88espo
What is your timing set at? Initial timing could have a huge effect on performance.
Old Jul 30, 2007 | 08:49 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Start TS with the cheap stuff first; fuel filter, then pump, then injectors.
Old Jul 30, 2007 | 09:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Buy or borrow a fuel pressure gauge, it helps to diagnose fuel delivery issues. http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
89 Bob L's Avatar
89 Bob L
Fuel Filter?
Fuel Injectors?
O-2 Sensor?
Timing?
Old Jul 30, 2007 | 06:18 PM
deerkill10's Avatar
deerkill10
I will check timing and test fuel pressure
none of the above will code?????
Old Jul 30, 2007 | 06:38 PM
Danspeed1's Avatar
Danspeed1
Originally Posted by 89 Bob L
Fuel Filter?
Fuel Injectors?
O-2 Sensor?
Timing?
+1
Check timing first...
Chances are its not the O2 sensor if its a problem on start up... I don't think (correct me if i am wrong guys) the vehicle goes into closed loop until about 160*F.
Old Jul 30, 2007 | 07:40 PM
Da Mail Man's Avatar
Da Mail Man
..cat converter on it's way out?
Old Jul 30, 2007 | 07:49 PM
jhammons01's Avatar
jhammons01
ding ding ding The winner.......
Old Jul 30, 2007 | 08:37 PM
All2kool's Avatar
All2kool
convertor removed
new temp sensor
123k on stock vette
It's PRIMING. Your car does not excellerate, it ACCELERATES.
Old Aug 4, 2007 | 03:54 PM
deerkill10's Avatar
deerkill10
#8 fouling plugs looks rich
could this be fuel trouble?????
or head trouble?????
Old Aug 4, 2007 | 07:52 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
excellerate : v, to move with rapid acceleration in a most excellent way!
I agree with All2kool in both respects. The problem is undoubtedly fuel/priming related and with the problems you describe, it most surely isn't excellerating.
If the fouling is due to a rich condition, I'd say that the #8 injector is leaking. This is probably the cause of the hard start condition and the mid-range acceleration problem. With 123k on the (most likely) original injectors, you really need all new or rebuilt injectors. Some year Vettes (89+) have multec injectors which were poor quality when new, and not worth rebuilding. The factory 88 injectors were Bosch or Lucas, and can easily be rebuilt by Rich at Cruzin Performance. You could also order replacements from several CF supporting vendors.
The 85-88 C4s have a special 9th injector that is used only for cold start conditions. There are no new replacements available form any OEM or after-market supplier. I would suggest that you have your original Cold-Start injector pulled and shipped to Rich for testing and reconditioning when you do the other 8 injectors. Replacing all of the injectors is a long one-weekend job that you can do yourself for a couple hundred dollars less than a shop would charge. Lots of labor, very little needed in tools or material.
To 88 corvette poor exceleration
