help quick won't start
Old Aug 6, 2007 | 07:09 PM
pipe's Avatar
pipe
What about what I mentioned earlier. The coolant temp. sensor at the front of the intake being bad? Pipe
Old Aug 6, 2007 | 08:27 PM
trackman44's Avatar
trackman44
Default posible vacuum leak?
If the MAP sensor sees close to atmosphere the injectors will probably inject more fuel than needed. Hook up a vacuum gage to the plenum and crank her over without putting your foot down on the gas ( throttle valve closed ). You should have a good strong reading approx 15-20in Hg. Also check to make sure your TPS is working properly. (0.45 volts at closed throttle, gradually opening throttle to WOT you should see a steady climb of voltage to ~5 volts. Any fluctuation in voltage reading while doing this means TPS is bad and needs replacing). Also MAP sensors can go bad by sending incorrect readings to the ECM. Also 5 volt supply to TPS and MAP sensors could be out of specs ( something lower or higher voltage) throwing the ECM off. The coolant sensor is there to give the ECM a base idle speed ( colder engines rev higher at idle than warmer). So, to recap, check all vacuum hoses to make sure you don't have a leak, check TPS voltage (the sense voltage), check 5 volt supply voltage to TPS and MAP and check sense voltage of MAP ( i'm not sure what it's supposed to be, check FSM).
Old Aug 6, 2007 | 10:21 PM
1990Redcoupe's Avatar
1990Redcoupe
By any chance have you done any previous work to the engine that could have resulted in spark plug wires being crossed, the distributor rotated or changed anything to do with ignition timing ?
Old Aug 6, 2007 | 11:10 PM
RRT vette's Avatar
RRT vette
A few things that come to mind. You mentioned the new spark plug tips are black/carboned. You could have weak spark. Make sure that you are getting atleast 1/2" spark on all 8. The fuel pressure seems to hold adequately enough. As long as the fuel pump is working properly, the fuel pressure will not drop off when cranking. Have you made sure the air passages are not blocked and the IAC is working? The IAC could be stuck closed and not letting air into the intake and causing you to have to hold the throttle open to supply enough air.
You apparently have a very rich condition gettin too much fuel, not enough air, or not enough spark. 24# injectors should not matter in this situation. The engine should still run on it's own and if anything just run rich, if that. The ECM is also a likely suspect. It would be nice if you had a spare to swap out, just to use as a troubleshooting tool. Do you know anyone around you with a 90 or 91 that would be willing to let you try?
If the timing was way off, it would cause a similar problem.
Old Aug 7, 2007 | 09:37 AM
wilsman's Avatar
wilsman
sounds like your cats might be plugged.if nothing else works try checking the cats,if they are still on the car
Old Aug 7, 2007 | 10:21 AM
arbee's Avatar
arbee
I don't know if the L98 coolant temperature sensor works the same as an LT1, but I just experienced the exact same symptoms on my 92. It turned out to be a faulty sensor. The coolant temperature sensor is just a thermistor which changes resistance with a change in temperature. In my FSM, it shows a chart of the resistance values that correspond to a specific temperature. I unplugged the sensor and placed a 3000 ohm resistor(which corresponds to an ambient temperature of approx. 72*) across the harness terminals and it fired right up. As the temperature of the engine increased, it began to run rough again so I replaced the resistor with a lower value one and it again ran smooth. With a faulty sensor, it was telling the ECM that it was in excess of -40* and the ECM was telling the injectors to supply too much fuel. Might be worth a try.
Old Aug 7, 2007 | 01:13 PM
RICH90's Avatar
RICH90
7th Gear
I had similar problem just not as bad . I replaced the ecu with the one from the junkyard ,it is a real common one i think mine came from a lumina $30 i just swapped out the prom. The car got better but still has a glitch . cheap fix if not peace of mind ruling out the ecu
Old Aug 7, 2007 | 01:19 PM
trackman44's Avatar
trackman44
If your running #24 injectors instead of #22 with high fuel pressure your going to get a rich condition. Adjust fuel pressure to a lower setting (40psi or lower) and then try to start again.
Old Aug 7, 2007 | 06:26 PM
pipe's Avatar
pipe
Ok here goes I tested a bunch of stuff under the hood today and maybe this will help you help me Battery 12.01 (not running) 4.67 volts to Coolant sensor 5.03 volts to MAP sensor Throttle Position sensor 0.551 (closed) then when I opened the Throttle all the way it was a steady climb to 4.36 volts Thats about all I could test. I still need to get a vacum gage and test that. THANKS AGAIN GUY'S YOU ARE A BIG HELP IN DIAGNOSING THIS PROBLEM. Pipe
Old Aug 7, 2007 | 06:30 PM
pipe's Avatar
pipe
I also tested the IAC and it was within the parameters. Im testing the sensors with the Mid America kit that has all the test connectors with the pigtails to use the volt/ohm meter with it. THANKS AGAIN Pipe
Old Aug 9, 2007 | 11:57 PM
trackman44's Avatar
trackman44
Default Coolant temp Is resistance measured
You have to measure the resistance coming off the coolant sensor to check to see if it's any good (voltage doesn't help on this sensor). Here's a table of resistance versus temp on good coolant sensors.
degrees F | Ohms
210 | 185
160 | 450
100 | 1,600
70 | 3,400
40 | 7,500
20 | 13,500
0 | 25,000
Take sensor out of vette, put in a small pot with water on the stove. Stick thermometer in pot. Attach ohmmeter to terminals of coolant sensor. Turn on stove and note the resistance readings versus temp. If they don't match to the table above( within 5% tolerence ), discard sensor and buy new sensor, do same test as above to make sure it works ( otherwise return sensor and get money back!), put in vette and then everything should work.
Old Aug 10, 2007 | 11:03 AM
engle1147's Avatar
engle1147
Default Gas May Be No Good / Contaminated!
"Car was really hard to start and smoking like crazy" before you changed the injectors?
If all is well drain the fuel in the tank, drain the fuel rails, lines and change the fuel filter....then add "new" gas.
Good luck!
Old Aug 10, 2007 | 06:25 PM
  #33
pipe's Avatar
pipe
Keep checking this post guy's i'm going to check some stuff and i'll keep ya informed. Pipe
Old Aug 11, 2007 | 08:18 AM
  #34
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you put a noid light into injector harness, yet ??
A bad coolant temp sensor made mine run like crap, but it set a code 15. You still have no codes ??
Old Aug 11, 2007 | 11:38 AM
  #35
senorv47's Avatar
senorv47
O2 sENSOR?
Old Aug 11, 2007 | 02:25 PM
  #36
pipe's Avatar
pipe
The sensors seem to check ok unless i'm checkin em wrong. I took a plug out (black sooty) and connected it to the plug wire and it seems to have constant steady blueish white spark when I cranked it over. I still had to hold my foot to the floor to get it started. Still had smoke from the exhaust (gassy smell ) seemed the longer it ran and the warmer it got the better it got. The idle seemed to smooth out and it stayed running when I took my foot off the pedal. When I went to jump on the throttle it stalled right away and then wouldn't start again till I put my foot to the floor. Pipe COULD BE THE ECM
Old Aug 11, 2007 | 08:44 PM
  #37
RRT vette's Avatar
RRT vette
pipe, if you could answer this question for us, it would help. Still sounds like the injectors are leaking or the ECM has a continous ground on the harness wire.
To help quick won't start
Old Aug 12, 2007 | 08:08 PM
  #38
pipe's Avatar
pipe
No I didn't hook a noid light to the injectors. The car has no cats on it. Long tube headers and good muffs. A friend is going to try and help me get a TECH #1 scanner from a GM mechanic he knows. What will the TECH 1 tell me and is it hard to operate? I'm going to remove the IAC and clean it and make sure it's seating right in the TB THANKS AGAIN Pipe
Old Aug 13, 2007 | 10:22 AM
  #39
trackman44's Avatar
trackman44
Default Coolanrt temp sensor?
Did you read my previous post about the coolant temp sensor? Have it checked.
Old Aug 13, 2007 | 05:34 PM
  #40
pipe's Avatar
pipe
Trackman 44 help me here man. I went up to Radio Shack and got a 3300 ohm resistor cause they didn't have a 3000 I unplugged the connector from the coolant temp sensor and jumped the resistor across the harness terminals. It started right up without putting my foot to the floor to start it. I let it run for about 10 to 15 min. like this with the resistor jumped across the connector. When I went to jump on the throttle after it was warm it stalled. Pipe THANK YOU GUY'S
