Fuel or ign??
Old Sep 4, 2007 | 12:57 PM
old guy with vette's Avatar
old guy with vette
Default Fuel or ign??
I am working on my son's 86 and so far can't find what's wrong. It starts fine, idles fairly well, and will accelerate slowly to WOT. Problem is that it won't accel quickly, just stumbles. I've installed new plugs, verified that the all inj check close to 16 ohm and timing has been set. I replaced a bad ign mod, runs better but still stumbles. I pulled the injector plugs while idleing but didn't notice a change. I've no experience w/ this, not sure what controls the fuel delivery. There are no codes since I replaced the inj mod. Can low voltage cause this? Am getting 14.3 v when running but the batt does go dead quickly.
I would appreciate some feedback on where to look. I plan on checking the coil tonight.
Old Sep 4, 2007 | 01:00 PM
pcolt94's Avatar
pcolt94
Check timing. Make sure the distributor has not turned or is loose. Check the advance in it if it has the mechanical.
Old Sep 4, 2007 | 01:23 PM
vader86's Avatar
vader86
Check fuel pressure, at idle and WOT.
Verify that spark is getting to each cylinder.
May want to double check MAF connections.
My money is on an electrical/wiring issue. My 86 is having them left and right.
Old Sep 4, 2007 | 02:07 PM
RRT vette's Avatar
RRT vette
I was having the almost exact problem with my 86 awhile back. It would start up fine, idle a little shakey, and drive like crap with slow accleleration. I checked everthing I could think of with no codes. I could set the timing with a timing light, ect.
Finally one day, I decided to check the position of the distrubitor. Found out that it was installed incorrectly by my father who told me it was right. If you can't believe your own father...who can you believe?
Anyhow, I got #1 piston to TDC, pulled the dist and realigned, and rerouted the spark plug wires. Started it up and ran like a new car. Before this, it would not even turn the tires over. Now I can do a burnout easily.
Get the #1 piston TDC and remove the dist cap and see if the tip of the rotor is pointing towards #1 cylinder or at the left rear tip of the plenum. It should take about 10-15 minutes to check this.
Old Sep 4, 2007 | 03:02 PM
SunCr's Avatar
SunCr
Check backpressure or just unbolt the CAT and go for a ride.
Old Sep 4, 2007 | 10:00 PM
old guy with vette
Thanks for the tip, the previous owner did say he installed a new dist. I'll check that and let you know.
Old Sep 4, 2007 | 10:03 PM
old guy with vette
Iv'e checked fuel press, will check the MAF connections.
Roger
Old Sep 4, 2007 | 10:24 PM
JackDidley's Avatar
JackDidley
Be sure and unhook the tan/black est wire when you set timing.
Old Sep 5, 2007 | 02:20 AM
86PACER's Avatar
86PACER
This one. It will thrown a code 42 naturally. Unplug battery for 10 min to clear.
Also, run the car with this plug disconnected to rule out a slipped timing mark. If it improves, you're probably setting the timing to a false timing line that has slipped.
Old Sep 5, 2007 | 09:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Roger
Checking the fuel pressure under heavy load would be a good idea. Does your gauge reach the windshield, so you can see the pressure under load ??
To Fuel or ign??
